[Qgis-user] QGis not running windows 7
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Fri Jun 24 09:33:04 PDT 2016
I also have anaconda (but 2.7) with no problems. That should not be the source. As a precaution, I did not specify anaconda as my main Python interpreter, but that should not be the issue (but keep it in mind).
I would try deleting the Qgis registry key and all Qgis folders like .qgis2 (hidden folder in Windows user path.). (Google Qgis complete uninstall). You could have an old plugin in the temporary folder creating this problem.
You also have 2 different installs. The easy install and the osgeo4w install. Try the OSGEO. Make sure you are not installing a 64bit version if your windows in 32bit.
It also help not to have any funny characters in the windows use name an user path like "Félix".
If that does not help tell us what install version you are using.
Good luck
Nicolas
On Jun 24, 2016 6:47 AM, "defelix [via OSGeo.org]" <ml-node+s1560n5273169h0 at n6.nabble.com> wrote:
Hi all,
I Installed QGis 2.14 Essen, but when I run it I can see the splshscreen for 2/3 seconds, then it disappear and QGis is not running.
Before I had QGis Lyon installed and working, then I uninstalled it for having the new version QGis essen.
The OS is window 7, I have also python 3.5.2 installed and anaconda.
Some of you encountered the same issue? any help?
thanks a lot
Defelix
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/QGis-not-running-windows-7-tp5273169.html
To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
To unsubscribe from Quantum GIS - User, click here .
NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/QGis-not-running-windows-7-tp5273169p5273241.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160624/2e88de9e/attachment.html>
