[Qgis-user] Exporting composer to PDF from command line
Richard Duivenvoorde rdmailings at duif.net
Tue Jun 28 00:23:49 PDT 2016
On 28-06-16 09:14, Samuel Ingarfield wrote:
> Hi All;
> Is there a way to export a specific composer to PDF from the command
> line or through python? I have a large number of print composers already
> defined for a particular project, and would like to export them all to
> PDF without having to open each individually and click the 'Export as
> PDF' button...
>From docs:
http://docs.qgis.org/testing/en/docs/pyqgis_developer_cookbook/composer.html#output-using-map-composer
does not show, how to find a named layout, but shows most you need I think?
Regards,
