[Qgis-user] Exporting composer to PDF from command line
DelazJ delazj at gmail.com
Tue Jun 28 01:51:35 PDT 2016
Samuel, there are also plugins available in QGIS that do such things:
MultiPrint and Maps Printer (from me, though not up to date with all the
recent improvements of print composer). Give them a try.
HTH,
Harrissou
2016-06-28 9:23 GMT+02:00 Richard Duivenvoorde <rdmailings at duif.net>:
> On 28-06-16 09:14, Samuel Ingarfield wrote:
> > Hi All;
> > Is there a way to export a specific composer to PDF from the command
> > line or through python? I have a large number of print composers already
> > defined for a particular project, and would like to export them all to
> > PDF without having to open each individually and click the 'Export as
> > PDF' button...
> From docs:
> http://docs.qgis.org/testing/en/docs/pyqgis_developer_cookbook/composer.html#output-using-map-composer
> does not show, how to find a named layout, but shows most you need I think?
> Regards,
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160628/9d03d4ae/attachment.html>
