[Qgis-user] pcs.csv parameters and Proj4
Idan Miara
idanool at gmail.com
Tue Jun 28 07:13:27 PDT 2016
I'm trying to decipher pcs.csv (Is there a documentation?):
my guess was:
PARAMETER_VALUE_1=lat_0
PARAMETER_VALUE_2=lon_0
PARAMETER_VALUE_3=k
PARAMETER_VALUE_4=x_0
PARAMETER_VALUE_5=y_0
But apparently that's not exactly the case for parameters 1+2, for instance
(EPSG:2036):
http://spatialreference.org/ref/epsg/2036/proj4/: (same as in QGIS CRS
window)
+proj=sterea +lat_0=46.5 +lon_0=-66.5 +k=0.999912 +x_0=2500000 +y_0=7500000
+ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs
pcs.csv:
PARAMETER_VALUE_1=46.3 (not 46.5)
PARAMETER_VALUE_2=-66.3 (not -66.5)
for other projections I checked there is also difference in parameters 1+2,
What am I missing here?
Also, Does QGIS "generate" a proj4 definition from the pcs/gcs/datum csv
files by EPSG codes? if so, how?
Best Regards,
Idan
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160628/d0ab5e8f/attachment.html>
