[Qgis-user] Next LTR RElease
Neumann, Andreas a.neumann at carto.net
Wed Jun 29 05:23:17 PDT 2016
There is a lot of confusion around the LTR version. Just to make it
clear: 2.14 will be advertised as LTR when 2.16 is released. The reason
is, that in order to be stable enough to be called an LTR it should
receive 2-3 bug fixing rounds. Many bug fixes that go into 2.16 are also
backported to 2.14x.
So expect 2.14 to be advertised as LTR once 2.16 is out - probably in
the second week of July.
Hope this helps to clarify.
Andreas
On 2016-06-29 14:08, Jonathan Moules wrote:
> 2.14 is an LTR? On the QGIS home page under the big Download Now button it says:
> "Version 2.14.3
> LTR Version 2.8.9"
> I'd suggest that should probably be updated to state that 2.14 is an LTR too.
> Cheers,
> Jonathan
> ---- On Tue, 28 Jun 2016 13:22:58 +0100 JÜRGEN E. FISCHER<JEF at NORBIT.DE> wrote ----
>> Hi Tyler,
>> On Tue, 28. Jun 2016 at 08:52:28 -0300, Tyler Veinot wrote:
>>> Hi, just wondering if anyone has an idea as to when the next LTR will be
>>> released. I was looking at the QGIS road map and from what I can tell LTR
>>> 2.14 was planned to be released 26 Feb 2016, I know plans change so I am
>>> wondering if there is a new ETA?
>> 2.14 was released in February and is the current LTR (ie. gets backports). But
>> hasn't yet replaced the previous LTR in the repositories. That will happen
>> when 2.16 is released and "fresh" 2.14 has seen four month of maintanance.
>> Jürgen
>> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
>> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
>> Software Engineer D-26506 Norden http://www.norbit.de
>> QGIS release manager (PSC) Germany IRC: jef on FreeNode
>> Qgis-user mailing list
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160629/88e82892/attachment.html>
