[Qgis-user] Pie charts in QGIS
Richard McDonnell
richard.mcdonnell at opw.ie
Thu Jun 30 02:56:19 PDT 2016
Giulia,
Are your labels on a separate Layer? you wont be able to move both
together if they are.
If you have everything on the one layer and the labels are associated
with the charts then its an easy enough task. You have 2 options.
* Manually move the point representing the location of the Pie Chart
you wish to locate, not the most ideal, but the quickest.
OR
* Add two additional columns to your table for an alternative *X* and
*Y* location coordinate (alt_x and alt_y for example) and use the
*Data defined positions* under *Placement* under *Diagrams* in the
*Layer Properties*. You can select the new columns as your
alternative locations. Use the field calculator to add the fields,
you can put the current X,Y coordinates in using *$X* for your X
coordinates and *$Y* for the Y coordinates.
You could also do the same for the labels if they are separate, and use
the move label tool, this will update your X and Y alternative
coordinates accordingly.
Hope this helps,
Regards,
Richard.
On 30/06/2016 09:58, Giulia Valvassori wrote:
> Dear all,
> I'm using qgis to depict data derived from population genetic analysis.
> For each sampling site i've got a pie chart with a specific label.
> Taking into account that some sampling sites are extremely closed to
> each other, do you know if there is an option that allows you to move
> directly with your mouse both pie charts and labels?
> Do you know if it is possible to modified the style of a pie chart
> (not only the colour) for example adding some effects like dots inside
> the pie charts.
> I'm working in a Windows 10 laptop with QGIS 2.14.2 Essen.
> Thank you very much in advance.
> Giulia
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
*_Richard McDonnell_*
*GIS Specialist PgD GIS AssocSCSI*
*OPW FRM Data Management*
*52 Stephens Green, Dublin 2.*
TEL: 01 6476543
OPW - Ag féachaint don am atá le teacht - Ag caomhnú ón am atá thart
OPW - Looking to the future - Caring for the past
Email Disclaimer: http://www.opw.ie/en/disclaimer/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160630/eb59a98f/attachment.html>
