[Qgis-user] Align points to lines
Luis Miguel Royo Perez luis.miguel.royo at gmail.com
Thu Jun 30 05:50:43 PDT 2016
I needed to do the same, and I found this postgis function:
http://postgis.net/docs/ST_ClosestPoint.html
Hope it helps!!
El 30/06/16 a las 14:45, Graham Walker escribió:
> need, but I use a combination of the following to snap a point shp to
> a line shp.
> v .to.points set at 0.5m distances on line layer (obviously the lower
> the more accurate)
> Distance to nearest hub from original point to newly created
> point,output as line
> Join attributes by location using v.to.points layer as target and
> nearest hub layer as join vector layer. Wet predicate to touches. Take
> attributes of first located feature and only keep matching records.
> You could probably query to find the closest line from each point
