[Qgis-user] QGIS 2.14 Essen for Censtos has several errors
Tudorache, Marian
Marian.Tudorache at navcanada.ca
Thu Jun 30 13:08:16 PDT 2016
Hi everyone,
I have finished the installation of QGIS 2.14 on Centos 7.
For example a lot of ui files uses QWebView which I have to replace with QTextBrowser.
Here is the list with errors:
1. vector.py from /usr/share/qgis/python/plugins/processing/tools.
a. Fails at the line import spatialite_utils because spatialite_utils;
b. Since I do not use spatialite I decided to comment out the line;
2. DlgResults.ui, DlgHelpEdition.ui, DlgAlgorithmBase.ui, DlgGetScriptsAndModels.ui contains QWebView but when these are loaded an error pops up: ImportError: No module named QtWebKit.QWebView.
a. I have found two possible solutions to fix this:
i. Replace the QWebView with QTextBrowser in ui file;
ii. Find the python file responsible with loading of each ui file and introduce the import statement:
From PyQt4.QtWebKit import QWebView
For example for DlgResults.ui file I have to modify the file ResultsDialog.py
I implemented the first fix
b. In the file ModelerParametersDialog.py I have added from PyQt4.QtGui import QTextBrowser as QWebView
i. I think you do not have to add this line if you implement the second fix from a)
3. ImportError: No module named Qsci.qsciscintilla on the file ui_console_compile_apis.py.
a. I had to replace the statement from Qsci.qsciscintilla import QsciScintilla with from PyQt4.Qsci import QsciScintilla
Please let me know if you have any question.
Marian
This electronic message, as well as any transmitted files included in the electronic message, may contain privileged or confidential information and is intended solely for the use of the individual(s) or entity to which it is addressed. If you have received this electronic message in error please notify the sender immediately and delete the electronic message. Any unauthorized copying, disclosure or distribution of the electronic message is strictly forbidden. NAV CANADA accepts no liability for any damage caused by any virus and/or other malicious code transmitted by this electronic communication.
Le présent message électronique et tout fichier qui peut y être joint peuvent contenir des renseignements privilégiés ou confidentiels destinés à l’usage exclusif des personnes ou des organismes à qui ils s’adressent. Si vous avez reçu ce message électronique par erreur, veuillez en informer l’expéditeur immédiatement et supprimez le. Toute reproduction, divulgation ou distribution du présent message électronique est strictement interdite. NAV CANADA n’assume aucune responsabilité en cas de dommage causé par tout virus ou autre programme malveillant transmis par ce message électronique.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160630/80be42e3/attachment.html>
