[Qgis-user] QGIS Viewer
Eric Goddard egoddard1010 at gmail.com
Thu Jun 30 13:44:03 PDT 2016
If you're using the OSGeo4W installer, you could uninstall the filegdb
api so that QGIS has to use the OpenFileGDB driver (which is read
only) to view file geodatabases. The QGIS stand-alone installer just
has the OpenFileGDB driver, so nothing extra is required there.
Eric
On Thu, Jun 30, 2016 at 1:56 PM, Heikki Vesanto
<heikki.vesanto at gmail.com> wrote:
> If you remove customise from the menu they will have to edit their registry
> to get it back. So will stop all but the most determined user.
> On 30 Jun 2016 19:27, "Brent Wood" <pcreso at yahoo.com> wrote:
>> And how do you stop a user from turning them on again?
>> Brent Wood
>> ________________________________
>> From: Heikki Vesanto <heikki.vesanto at gmail.com>
>> To: tech at wildintellect.com
>> Cc: qgis-user <qgis-user at lists.osgeo.org>
>> Sent: Friday, July 1, 2016 6:18 AM
>> Subject: Re: [Qgis-user] QGIS Viewer
>> You can hide most of the interface using the settings>customise menu, no
>> plugin required.
>> On 30 Jun 2016 18:30, "Alex M" <tech_dev at wildintellect.com> wrote:
>> On 06/30/2016 09:40 AM, James Keener wrote:
>> > How are users accessing the data?  If they're connecting to a
>> > database, can you simply not give them update permission?  If it's
>> > files, can you can keep read-only master copies on a public
>> > store/shared drive?
>> > Jim
>> > On Thu, Jun 30, 2016 at 12:20 PM, Tyler Veinot <tylerkveinot at gmail.com>
>> > wrote:
>> >> Hi again;
>> >> Just wondering if there is a QGIS Viewer available, or any suggestions
>> >> as to
>> >> what I can use that is open source with some basic spatial search
>> >> capabilities and can view filegeodatabases?
>> >> I have been deploying QGIS to our staff to view our GIS Data and I am
>> >> starting to get a little nervous where someone could easily do some
>> >> awesome
>> >> geoprocessing damage to our data if they got to messing about. So does
>> >> QGIS
>> >> have something like Esri's Arc Explorer?
>> >> Thanks
>> >> Tyler
>> The other approach I've seen is to use a plugin to disable and hide most
>> of the interface.
>> Thanks,
>> Alex
>> Qgis-user mailing list
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
