[Qgis-user] QGIS Viewer
Tyler Veinot tylerkveinot at gmail.com
Thu Jun 30 21:00:15 PDT 2016
Well there seems to be plenty of options; I like the idea of disabling some of the interface options. I highly doubt too many of my coworkers know how to access the registry and those that do I am not worried about making edits.
Thanks all.
Cheers
Sent from my Bell Sony device over Canada’s largest network.
---- Eric Goddard wrote ----
>If you're using the OSGeo4W installer, you could uninstall the filegdb
>api so that QGIS has to use the OpenFileGDB driver (which is read
>only) to view file geodatabases. The QGIS stand-alone installer just
>has the OpenFileGDB driver, so nothing extra is required there.
>Eric
>On Thu, Jun 30, 2016 at 1:56 PM, Heikki Vesanto
><heikki.vesanto at gmail.com> wrote:
>> If you remove customise from the menu they will have to edit their registry
>> to get it back. So will stop all but the most determined user.
>> On 30 Jun 2016 19:27, "Brent Wood" <pcreso at yahoo.com> wrote:
>>> And how do you stop a user from turning them on again?
>>> Brent Wood
>>> ________________________________
>>> From: Heikki Vesanto <heikki.vesanto at gmail.com>
>>> To: tech at wildintellect.com
>>> Cc: qgis-user <qgis-user at lists.osgeo.org>
>>> Sent: Friday, July 1, 2016 6:18 AM
>>> Subject: Re: [Qgis-user] QGIS Viewer
>>> You can hide most of the interface using the settings>customise menu, no
>>> plugin required.
>>> On 30 Jun 2016 18:30, "Alex M" <tech_dev at wildintellect.com> wrote:
>>> On 06/30/2016 09:40 AM, James Keener wrote:
>>> > How are users accessing the data?  If they're connecting to a
>>> > database, can you simply not give them update permission?  If it's
>>> > files, can you can keep read-only master copies on a public
>>> > store/shared drive?
>>> > Jim
>>> > On Thu, Jun 30, 2016 at 12:20 PM, Tyler Veinot <tylerkveinot at gmail.com>
>>> > wrote:
>>> >> Hi again;
>>> >> Just wondering if there is a QGIS Viewer available, or any suggestions
>>> >> as to
>>> >> what I can use that is open source with some basic spatial search
>>> >> capabilities and can view filegeodatabases?
>>> >> I have been deploying QGIS to our staff to view our GIS Data and I am
>>> >> starting to get a little nervous where someone could easily do some
>>> >> awesome
>>> >> geoprocessing damage to our data if they got to messing about. So does
>>> >> QGIS
>>> >> have something like Esri's Arc Explorer?
>>> >> Thanks
>>> >> Tyler
>>> The other approach I've seen is to use a plugin to disable and hide most
>>> of the interface.
>>> Thanks,
>>> Alex
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160701/3a95e279/attachment.html>
