[Qgis-user] advanced digitizing panel
Jake Maier j.m at jmforestry.com
Tue Mar 1 10:27:36 PST 2016
Hallo Werner
Danke für den Volltreffer in´s blaue.
Thanks for the perfect shot into the blue. I thought it would work like in other occasions, where if snapping is enabled but nothing to snap into is around that it just uses the pointer location.
Jake
-----Original Message-----
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Werner Macho
Sent: Tuesday, March 01, 2016 12:21 PM
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] advanced digitizing panel
Hi
A guess into the blue - did you probably set some snapping options?
regards
Werner
On 01/03/16 17:46, Jake Maier wrote:
> It’s driving me nuts. Seems to be so straight forward and I don’t get it.
> The advanced digitizing panel tool seems to work sometimes as
> expected, and at times I cannot draw the actual leg of a line or polygon.
> When I enter angle and distance, the tool draws the rubber band all
> right but when I click the endpoint it does not draw the actual polygon.
> Sometimes it will but most of the time it does not add the segment to
> the feature.
> There are not so many things to adjust on the tool, but I can’t figure
> out what I do wrong or misunderstand.
> Can someone please put me on the right track
> Thanks
> Jake
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
