[Qgis-user] advanced digitizing panel
Werner Macho werner.macho at gmail.com
Tue Mar 1 09:21:29 PST 2016
Hi
A guess into the blue - did you probably set some snapping options?
regards
Werner
On 01/03/16 17:46, Jake Maier wrote:
> It’s driving me nuts. Seems to be so straight forward and I don’t get it.
> The advanced digitizing panel tool seems to work sometimes as expected,
> and at times I cannot draw the actual leg of a line or polygon.
> When I enter angle and distance, the tool draws the rubber band all
> right but when I click the endpoint it does not draw the actual polygon.
> Sometimes it will but most of the time it does not add the segment to
>  the feature.
> There are not so many things to adjust on the tool, but I can’t figure
> out what I do wrong or misunderstand.
> Can someone please put me on the right track
> Thanks
> Jake
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
