[Qgis-user] GDAL/OGR : different compiled/running versions
Thomas Williamson wiltoma at gmail.com
Wed Mar 2 12:46:06 PST 2016
Thank you Andre! I managed to follow these steps:
   1. sudo apt-get purge -auto--remove qgis
   2. sudo apt-get clean
   3. sudo apt-get install python-software-properties
   4. sudo add-apt-repository ppa:ubuntugis/ubuntugis-unstable
   5. sudo apt-get update
   6. sudo apt-get install qgis python-qgis qgis-plugin-grass
This installed QGIS 2.8 on my machine, BUT the compiled / running GDAL/OGR
versions are now both 1.11.2 and Heatmaps plugin is showing the output
format drop-down list!
This is nearly perfect then, except that I lost the last up-to-date QGIS
version. Would you know what I could have missed to start back to QGIS 2.8?
Thanks again!
Thomas
2016-03-02 15:31 GMT+01:00 Andre Joost <andre+joost at nurfuerspam.de>:
> Am 02.03.2016 um 13:35 schrieb Thomas Williamson:
>> Hello all,
>> I'm working with QGIS 2.14 and LinuxMint.
>> I'm having difficulties running the Heatmaps plugin with the following
>> issue: the output format field is empty (the drop-down list is empty). I
>> found some help on this topic in this post
>> http://gis.stackexchange.com/questions/167257/workarounds-for-heatmap-plugin-in-qgis
>> The problem could come from this difference in Help > About window (see
>> attached screenshot):
>>     - Compiled against GDAL/OGR : 1.10.1
>>     - Running against GDAL/OGR : 1.11.2
>> I have completely removed QGIS and dependencies, and reinstalled it
>> completely but the problem is still there. How could I make GDAL/OGR
>> compiled and running versions identical?
>> As I'm quite new to Linux world, I would really appreciate a little help
>> on
>> how to achieve that with command lines.
> I'm not sure what repository you used, but my version of QGIS 2.14 on
> Linux Mint is compiled against and running with GDAL 1.11.2. I used the
> qgis.org ubuntugis trusty main repo, with the ubuntugis unstable ppa.
> It might help to remove GDAL and QGIS, do "sudo apt-get clean" to clear
> the cache, and reinstall with ubuntugis dependencies.
> BTW the windows version of QGIS 2.14 already uses GDAL 2.0.2.
> HTH,
> André Joost
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160302/1691019a/attachment.html>
