[Qgis-user] QGIS 2.14 with MS SQL Server
Martin Bain Martin.Bain at lismore.nsw.gov.au
Thu Mar 3 18:31:27 PST 2016
Thank you for the info Nyall.
From: Nyall Dawson [mailto:nyall.dawson at gmail.com]
Sent: Friday, 4 March 2016 12:08 PM
To: Martin Bain <Martin.Bain at lismore.nsw.gov.au>
Cc: qgis-user <qgis-user at lists.osgeo.org>
Subject: Re: [Qgis-user] QGIS 2.14 with MS SQL Server
On 4 Mar 2016 11:58 AM, "Martin Bain" <Martin.Bain at lismore.nsw.gov.au<mailto:Martin.Bain at lismore.nsw.gov.au>> wrote:
> Is anyone using QGIS 2.14 with MS SQL Server?  I just upgraded from 2.12 to 2.14 and encountered some very strange behaviours.
Yes, there was a bug in 2.14. It's been fixed in master and will be included in 2.14.1 when it's released.
Nyall
> These include: Whole columns of data displaying as NULL in the attribute table (even though there are no nulls in the table in SQL Server).
> And:  Numeric strings in text fields being treated as numbers.  For example I have a text field in a record that contains the string “2.0” (without the inverted commas) but it is being displayed as “2” in the attribute table, the info tool and as a label.  I tried to edit the text by retyping “2.0” but when I tabbed out of the textbox it was converted to “2”. The layer properties show the field type as QString.
> I have only had the chance to test it on one machine so far, so I don’t want generate unnecessary noise posting a bug report if it is just my machine that has a problem.
> So, is anyone here successfully using QGIS 2.14 and SQL Server (2008)?
> Thanks,
> Martin.
> This email is intended for the named recipient only. The information it contains may be confidential. If you are not the intended recipient you must not reproduce or distribute any part of this email, disclose its contents to any other party or take any action in reliance on it. If you have received this email in error, please contact the sender immediately and delete the message.
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160304/62867773/attachment.html>
