[Qgis-user] OpenGeo QGIS webappbuilder plugin error
Luigi Pirelli luipir at gmail.com
Fri Mar 4 05:25:31 PST 2016
wonderful
the question is... how do you have Processing 2.12 installed for Boundless QGIS?
one of the possible explication is that you have other QGIS installed
(e.g. community qgis with higher version).
But the plugin path is the same for all (if not configured in different way)
Btw... Boundless QGIS is almos similar to community qgis (the source
code is the same) but is packaged with internal developed plugins and
tested in a complex environment.
We give support to our packaged qgis in the OpenGeo suite env.
regards
Luigi Pirelli
* Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS:
https://www.packtpub.com/application-development/mastering-qgis
On 4 March 2016 at 14:19, Hanlie Pretorius <hanlie.pretorius at gmail.com> wrote:
> Yay!
> I downgraded the processing plugin using Plugin Manager and that fixed
> both processing and webappbuilder.
> Thanks for the help.
> Hanlie
> 2016-03-04 15:00 GMT+02:00, Hanlie Pretorius <hanlie.pretorius at gmail.com>:
>> Thanks for helping.
>> OpenGeo Suite version 4.8
>> webappbuilder plugin version
>> 0.1-20150803-745BF17B0B05A4BB9447E0899FCA2BB66AEAD4E
>> processing plugin version 2.12.2
>> For the last one the error message is:
>> This plugin is incompatible with this version of QGIS
>> Plugin designed for QGIS 2.12 - 2.99
>> The OpenGeo QGIS version is 2.8.3, so I guess I should try replacing
>> the processing viewer with version 2.10.3.
>> https://plugins.qgis.org/plugins/processing/
>> Will try that and let you know how it turns out.
>> 2016-03-04 14:52 GMT+02:00, Luigi Pirelli <luipir at gmail.com>:
>>> Hi Hanlie
>>> glad you are learning OpenGeo
>>> I would ask you more info about the problem
>>> webappbuilder plugin version (from plugin manager)
>>> and
>>> processing plugin version (from plugin manager)
>>> regards
>>> Luigi Pirelli
>>> * Mastering QGIS:
>>> On 4 March 2016 at 13:29, Hanlie Pretorius <hanlie.pretorius at gmail.com>
>>> wrote:
>>>> Hi,
>>>> I'm working on Windows 8.1.
>>>> I have downloaded and installed QGIS for OpenGeo and the webappbuilder
>>>> plugin fails to load with the following error:
>>>> Couldn't load plugin webappbuilder due to an error when calling its
>>>> classFactory() method"
>>>> All the information I could find on the web about this error have not
>>>> helped me.
>>>> In the Plugin Manager the Uninstall plugin and Reinstall plugin
>>>> buttons are disabled. It shows a message:
>>>> This plugin is broken
>>>> cannot import name show_message_log
>>>> I have uninstalled and reinstalled OpenGeo QGIS several times but it
>>>> makes no difference.
>>>> Does someone know how to fix this plugin? I would really like to use
>>>> it to start learning how to use OpenGeo.
>>>> Thanks
>>>> Hanlie
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
