[Qgis-user] GDAL/OGR : different compiled/running versions
Mike mswope at gmail.com
Fri Mar 4 09:53:14 PST 2016
Honestly, some directions like how syncthing does it would be nice.
https://apt.syncthing.net/
I would love to see the latest qgis on the latest ubuntu (15.10, soon
16.04).
On Thu, Mar 3, 2016 at 9:53 AM, Andre Joost <andre+joost at nurfuerspam.de>
wrote:
> Am 03.03.2016 um 15:48 schrieb Jürgen E. Fischer:
>> Hi Bernd,
>> On Thu, 03. Mar 2016 at 13:48:27 +0100, Bernd Vogelgesang wrote:
>>> Download page says:
>>> "If you use one of our ubuntugis based repositories you also need to
>>> add following line:
>>> deb     http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu
>>> *codename* main"
>> [...]for me this clearly says that you have to activate
>>> http://qgis.org/ubuntugis plus the ppa! So where are the "differences"
>>> then?
>> Because that's what it's supposed to say.
>> If you go without our qgis.org/ubuntugis repository you might get the
>> old qgis
>> version from the ubuntugis ppa, if you use a distribution that ubuntugis
>> has
>> one for.
> That's the confusing part. For earlier versions of QGIS, you could use
> either the ppa alone, or qgis.org.
>> Actually, when installing/upgrading, I always do a lot of trial and
>>> error until the stuff works as expected (having all the bells and
>>> whistles of ubuntugis, otherwise qgis is quite crippled!) without
>>> being able to memorize which combination did the trick in the end.
> Me too. And if you want the latest GDAL 2.0, you only get it for Windows,
> or Debian unstable. Any chance to get it into Ubuntugis too?
> Only two more lines of explanation in the documentation would do the
>>> trick to prevent users from planlessly installing/unistalling/adding
>>> repos/removing repos I think.
>> Which two lines?
> "Using the ubuntugis ppa alone (as encouraged for earlier versions to get
> the best in GIS) does not give you the latest QGIS version."
> And a small hint for Linux Mint users that ubuntugis trusty is the right
> one, might be good also.
> HTH,
> André Joost
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160304/cf09705e/attachment.html>
