[Qgis-user] how to upgrade from 2.8.2 to 2.8.7
Alex M tech_dev at wildintellect.com
Fri Mar 4 10:20:09 PST 2016
I believe if you run OSGeo4w in Advanced mode you will see 2 options for
QGIS, one being the latest and the other being Stable/LTR (You can
actually install both). Someone more familiar could better guide you on
the exact names.
Otherwise you can install the standalone
http://qgis.org/downloads/QGIS-OSGeo4W-2.8.7-1-Setup-x86_64.exe
Thanks,
Alex
On 03/04/2016 09:49 AM, Tom Rockclimber wrote:
> Windows 8, 64 bit.
> I was using the osgeo4w-setup-x86_64.exe(file date 6/7/2015) advanced
> install method.
> On Fri, Mar 4, 2016 at 9:47 AM, Alex M <tech_dev at wildintellect.com> wrote:
>> On 03/04/2016 09:38 AM, Tom Rockclimber wrote:
>>> there doesn't appear to be a way to upgrade from 2.8.2 to 2.8.7, the only
>>> option is to go to 2.14?
>>> due to collaboration, I want to stay on 2.8.x
>>> thanks,
>>> Tom
>> Tom,
>> What operating system are you using? Old installers are generally
>> available for Windows and Mac. If you're on linux then its slightly more
>> complicated.
>> Thanks,
>> Alex
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
