[Qgis-user] fields are not updated with calculated field values in QGIS 2.14
Alexandre Neto senhor.neto at gmail.com
Sat Mar 5 15:18:14 PST 2016
Hi Roy,
Are you sure your data is UTM 34 S? How did you convert the data to that
crs? What are the approximated coordinates values of your data
A sáb, 5/03/2016, 20:01, Roy Marsh <roymarsh11 at gmail.com> escreveu:
> Hi
> As a relative newcomer I have been working through the QGIS 2.14 training
> manual. Section 4.3.3 explains how to add calculated values using the Field
> Calculator.
> But when I do this ..(the examples are from 2.8 but the same procedure
> seems to apply to 2.14)..  the value stays as 0. It does this whatever
> parameters I try. It does this for both 'new field' and 'update field.' It
> does this even if layers are reprojected to UTM 34S (so as to show area in
> metres, not degrees).
> Is this a bug?
> Thanks
> Roy
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
Alexandre Neto
@AlexNetoGeo
http://sigsemgrilhetas.wordpress.com
http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160305/e63524fd/attachment.html>
