[Qgis-user] OpenGeo QGIS tutorial - publishing fails
Hanlie Pretorius hanlie.pretorius at gmail.com
Wed Mar 9 01:58:17 PST 2016
Hi Luigi,
Thanks for the response.
I installed the Geoserver Explorer plugin and I can now publish the DEM, thanks.
Regards
Hanlie
2016-03-08 10:16 GMT+02:00, Luigi Pirelli <luipir at gmail.com>:
> Hi Hanlie
> Yes, probably that part of documentation have to be updated.
> OpenGeo plugin, since months has been substitute with Geoserver explorer
> plugin.
> You should install it using common Plugin Manager.
> https://plugins.qgis.org/plugins/geoserverexplorer/
> Check if you replicate the error with the new plugin version.
> From OpenGeo plugin, the Postgis and QGIS Project parts has been
> removed to use the standard QGIS functions (DB Manager and Browser).
> regards
> Luigi Pirelli
> * Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
> * LinkedIn: https://www.linkedin.com/in/luigipirelli
> * Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
> * GitHub: https://github.com/luipir
> * Mastering QGIS:
> https://www.packtpub.com/application-development/mastering-qgis
> On 7 March 2016 at 10:53, Hanlie Pretorius <hanlie.pretorius at gmail.com>
> wrote:
>> Hi,
>> I'm busy running through the tutorial at
>> http://suite.opengeo.org/docs/latest/qgis/explorer/tutorial/index.html
>> but at step 10, after I click OK to publish the 'dem' layer (a
>> raster), I get the following error:
>> 'QgsRasterLayer' object has no attribute 'geometryType'
>> Traceback (most recent call last):
>>   File
>> "C:/PROGRA~2/BOUNDL~1/QGIS/qgis/apps/qgis/./python/plugins\opengeo\gui\explorer.py",
>> line 111, in run
>>     command(*params)
>>   File
>> "C:/PROGRA~2/BOUNDL~1/QGIS/qgis/apps/qgis/./python/plugins\opengeo\qgis\catalog.py",
>> line 475, in publishLayer
>>     sld = self.publishStyle(layer, overwrite, name)
>>   File
>> line 148, in publishStyle
>>     sld, icons = getGsCompatibleSld(layer)
>>   File
>> "C:/PROGRA~2/BOUNDL~1/QGIS/qgis/apps/qgis/./python/plugins\opengeo\qgis\sldadapter.py",
>> line 199, in getGsCompatibleSld
>>     return adaptQgsToGs(sld, layer)
>>   File
>> line 61, in adaptQgsToGs
>>     if layer.geometryType() == QGis.Point:
>> AttributeError: 'QgsRasterLayer' object has no attribute 'geometryType'
>> When I Googled it, I just get one unanswered question in StackExchange:
>> http://gis.stackexchange.com/questions/183100/qgis-opengeo-explorer-plugin-fails-when-publishing-with-qgsrasterlayer-object
>> Does anyone know what is going on?
>> Thanks
>> Hanlie
>> Qgis-user mailing list
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
