[Qgis-user] Pie charts i QGIS 2.14
Neumann, Andreas a.neumann at carto.net
Fri Mar 11 04:10:32 PST 2016
Hi Magnus,
And what exactly isn't working with the exiting diagrams --> Pie Charts
functionality?
What you list below should all be possible.
The third point, the size intervals, is a bit more tricky, because by
default, QGIS scales continuous (without fixed interval). But with a
QGIS expression you can also force the size to discrete steps. You could
divide/round the data in the expression to force it into discrete steps
for sizing the pie chart.
So - can you be more specific - what exactly doesn't work as expected?
Note, if you don't need pies (no subdivisions), but just proportional
symbols, you should better use the simple renderer, choose a symbol and
use the size-assistant. The size assistant can be found at this
drop-down button next to the Size input widget.
Andreas
On 2016-03-11 12:42, johnrobot wrote:
> Hi
> I would like to draw pie charts/circles for a polygon layer using data from
> the attribute table, for example population data. I have tried using
> properties- diagram, but it doesn´t seem to match what I am looking for. I
> would like to see this:
> - Based on attribute values, draw pie charts/circles.
> - Let me choose outline and fill colours/patterns.
> - Let me choose data intervals and the circle size for each interval.
> What would be the best way of achieving this in QGIS? I found
> https://github.com/LCacheux68224/ProportionalCircles, but it seems that I
> have to involve our IT department to install QGIS plugins, since I do not
> have admin rights on my computer.
> Regards,
> Magnus
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Pie-charts-i-QGIS-2-14-tp5255823.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160311/ca565603/attachment.html>
