[Qgis-user] MS Access and QGIS
Goyo goyodiaz at gmail.com
Fri Mar 11 06:17:42 PST 2016
I think you should be able to do that according to
http://docs.qgis.org/2.8/en/docs/user_manual/introduction/getting_started.html#command-line-options
Create a QGIS project including the parcels layer, compute the
bounding box of the selected layer(s) in the frontend, invoke QGIS
passing the project file name and the bounding box as parameters to
options:
qgis --project yourproject.qgs --extent xmin,ymin,xmax,ymax
It looks like you could even pass just a postgis layer instead of a
project file, but I don't know whay syntax you should be using.
Goyo
2016-03-08 14:05 GMT+01:00 "Sebastian Teßmer" <SebastianTessmer at gmx.de>:
> Hello everybody,
> today again something else to ask.
> I have an Access - database, which is stored with a PostGIS database.
> It serves as a kind of front end. Now I want to select a parcel in a form
> and then jump right in QGIS then.
> Maybe I would also select multiple parcels in form, which then in QGIS
> are being emphasized.
> I know that sounds very utopian, but maybe someone has an idea how to go
> that can
> or perhaps another suggestion on how to implement that.
> Thank you so much!
> MfG Sebastian
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
