[Qgis-user] OSX QGIS 2.14
William Kyngesburye woklist at kyngchaos.com
Sun Mar 13 17:55:48 PDT 2016
I haven't been keeping up on OTB.  I'll work on getting it up to date in the QGIS package.
> On Mar 13, 2016, at 1:34 PM, Pieter du Plooy <pjduplooy at zpanelcp.com> wrote:
> As an interim solution modify the minimum version part in OTBUtils.py to 4.4.0
> On Sun, Mar 13, 2016 at 7:47 PM, Pieter du Plooy <pjduplooy at zpanelcp.com> wrote:
> Further info, OTBUtils.py contains:
> supportedVersions = {"5.0.0": "5.0.0"}
> On Sun, Mar 13, 2016 at 7:32 PM, Pieter du Plooy <pjduplooy at zpanelcp.com> wrote:
> Olav, Ricardo
> None of that helped.
> The log viewer for Processing states :
> Problem with OTB installation: installed OTB version (4.4.0) is not supported
> On Sun, Mar 13, 2016 at 3:08 PM, Olav Peeters <opeeters at gmail.com> wrote:
> Ricardo,
> the latest Boundless QGIS version for OSX is 2.8.3, no?
> Pieter,
> I just tried orfeo-toolbox processing tools in Kyngchaos' QGIS 2.14 on Yosemite. All seems well, but I've not yet used these tools extensively..
> But if all else works on Mavericks it's a bit strange that the orfeo-toolbox is not listed. Have you tried rebooting? I had a similar issue once which was solve with a reboot.. Did you remove the previous QGIS version (also from trash)? Maybe try removing ~/.qgis2 and relaunch QGIS. Don't forget to back-up your settings if you did a lot of customisations..
> Cheers,
> Olav
> On 13/03/16 13:17, Ricardo Pinho wrote:
>> Hi Pieter,
>> Have you tried the Boundless QGIS version?
>> http://boundlessgeo.com/products/downloads/qgis-download-request/
>> (select MAC on the "Desktop Operating System")
>> Cheers,
>> Ricardo Pinho
>> 2016-03-13 10:22 GMT+00:00 Pieter du Plooy <pjduplooy at zpanelcp.com>:
>> Hi guys.
>> I wanted to use Kyngchaos' QGIS 2.14 on my Mavericks Machine (I know its 2016, and were supposed to use Yosemite or El Cap, but there is a long reason for that lol), and I can use it, although the orfeo-toolbox processing does not work.
>> Although the otb apps are available in the package, and it is enabled in Processing, it does not appear in the toolbox.
>> William K, or anyone else, any hints or guidance?
>> Regards, Pieter
>> Qgis-user mailing list
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Ricardo Pinho
>> List info:
>> Unsubscribe:
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
[Trillian]  What are you supposed to do WITH a maniacally depressed robot?
[Marvin]  You think you have problems?  What are you supposed to do if you ARE a maniacally depressed robot?  No, don't try and answer, I'm 50,000 times more intelligent than you and even I don't know the answer...
- HitchHiker's Guide to the Galaxy
