[Qgis-user] OSX QGIS 2.14
Pieter du Plooy pjduplooy at zpanelcp.com
Sun Mar 13 11:34:25 PDT 2016
As an interim solution modify the minimum version part in OTBUtils.py to
4.4.0
On Sun, Mar 13, 2016 at 7:47 PM, Pieter du Plooy <pjduplooy at zpanelcp.com>
wrote:
> Further info, OTBUtils.py contains:
> supportedVersions = {"5.0.0": "5.0.0"}
> On Sun, Mar 13, 2016 at 7:32 PM, Pieter du Plooy <pjduplooy at zpanelcp.com>
> wrote:
>> Olav, Ricardo
>> None of that helped.
>> The log viewer for Processing states :
>> Problem with OTB installation: installed OTB version (4.4.0) is not
>> supported
>> On Sun, Mar 13, 2016 at 3:08 PM, Olav Peeters <opeeters at gmail.com> wrote:
>>> Ricardo,
>>> the latest Boundless QGIS version for OSX is 2.8.3, no?
>>> Pieter,
>>> I just tried orfeo-toolbox processing tools in Kyngchaos' QGIS 2.14 on
>>> Yosemite. All seems well, but I've not yet used these tools extensively..
>>> But if all else works on Mavericks it's a bit strange that the
>>> orfeo-toolbox is not listed. Have you tried rebooting? I had a similar
>>> issue once which was solve with a reboot.. Did you remove the previous QGIS
>>> version (also from trash)? Maybe try removing ~/.qgis2 and relaunch QGIS.
>>> Don't forget to back-up your settings if you did a lot of customisations..
>>> Cheers,
>>> Olav
>>> On 13/03/16 13:17, Ricardo Pinho wrote:
>>> Hi Pieter,
>>> Have you tried the Boundless QGIS version?
>>> http://boundlessgeo.com/products/downloads/qgis-download-request/
>>> (select MAC on the "Desktop Operating System")
>>> Cheers,
>>> Ricardo Pinho
>>> 2016-03-13 10:22 GMT+00:00 Pieter du Plooy <pjduplooy at zpanelcp.com>:
>>>> Hi guys.
>>>> I wanted to use Kyngchaos' QGIS 2.14 on my Mavericks Machine (I know
>>>> its 2016, and were supposed to use Yosemite or El Cap, but there is a long
>>>> reason for that lol), and I can use it, although the orfeo-toolbox
>>>> processing does not work.
>>>> Although the otb apps are available in the package, and it is enabled
>>>> in Processing, it does not appear in the toolbox.
>>>> William K, or anyone else, any hints or guidance?
>>>> Regards, Pieter
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Ricardo Pinho
>>> Qgis-user mailing listQgis-user at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160313/cc46e7a4/attachment.html>
