[Qgis-user] OSX QGIS 2.14
Pieter du Plooy pjduplooy at zpanelcp.com
Sun Mar 13 10:47:01 PDT 2016
Further info, OTBUtils.py contains:
supportedVersions = {"5.0.0": "5.0.0"}
On Sun, Mar 13, 2016 at 7:32 PM, Pieter du Plooy <pjduplooy at zpanelcp.com>
wrote:
> Olav, Ricardo
> None of that helped.
> The log viewer for Processing states :
> Problem with OTB installation: installed OTB version (4.4.0) is not
> supported
> On Sun, Mar 13, 2016 at 3:08 PM, Olav Peeters <opeeters at gmail.com> wrote:
>> Ricardo,
>> the latest Boundless QGIS version for OSX is 2.8.3, no?
>> Pieter,
>> I just tried orfeo-toolbox processing tools in Kyngchaos' QGIS 2.14 on
>> Yosemite. All seems well, but I've not yet used these tools extensively..
>> But if all else works on Mavericks it's a bit strange that the
>> orfeo-toolbox is not listed. Have you tried rebooting? I had a similar
>> issue once which was solve with a reboot.. Did you remove the previous QGIS
>> version (also from trash)? Maybe try removing ~/.qgis2 and relaunch QGIS.
>> Don't forget to back-up your settings if you did a lot of customisations..
>> Cheers,
>> Olav
>> On 13/03/16 13:17, Ricardo Pinho wrote:
>> Hi Pieter,
>> Have you tried the Boundless QGIS version?
>> http://boundlessgeo.com/products/downloads/qgis-download-request/
>> (select MAC on the "Desktop Operating System")
>> Cheers,
>> Ricardo Pinho
>> 2016-03-13 10:22 GMT+00:00 Pieter du Plooy <pjduplooy at zpanelcp.com>:
>>> Hi guys.
>>> I wanted to use Kyngchaos' QGIS 2.14 on my Mavericks Machine (I know its
>>> 2016, and were supposed to use Yosemite or El Cap, but there is a long
>>> reason for that lol), and I can use it, although the orfeo-toolbox
>>> processing does not work.
>>> Although the otb apps are available in the package, and it is enabled in
>>> Processing, it does not appear in the toolbox.
>>> William K, or anyone else, any hints or guidance?
>>> Regards, Pieter
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Ricardo Pinho
>> Qgis-user mailing listQgis-user at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160313/566be6b7/attachment.html>
