[Qgis-user] OSX QGIS 2.14
Pieter du Plooy pjduplooy at zpanelcp.com
Sun Mar 13 10:32:55 PDT 2016
Olav, Ricardo
None of that helped.
The log viewer for Processing states :
Problem with OTB installation: installed OTB version (4.4.0) is not
supported
On Sun, Mar 13, 2016 at 3:08 PM, Olav Peeters <opeeters at gmail.com> wrote:
> Ricardo,
> the latest Boundless QGIS version for OSX is 2.8.3, no?
> Pieter,
> I just tried orfeo-toolbox processing tools in Kyngchaos' QGIS 2.14 on
> Yosemite. All seems well, but I've not yet used these tools extensively..
> But if all else works on Mavericks it's a bit strange that the
> orfeo-toolbox is not listed. Have you tried rebooting? I had a similar
> issue once which was solve with a reboot.. Did you remove the previous QGIS
> version (also from trash)? Maybe try removing ~/.qgis2 and relaunch QGIS.
> Don't forget to back-up your settings if you did a lot of customisations..
> Cheers,
> Olav
> On 13/03/16 13:17, Ricardo Pinho wrote:
> Hi Pieter,
> Have you tried the Boundless QGIS version?
> http://boundlessgeo.com/products/downloads/qgis-download-request/
> (select MAC on the "Desktop Operating System")
> Cheers,
> Ricardo Pinho
> 2016-03-13 10:22 GMT+00:00 Pieter du Plooy <pjduplooy at zpanelcp.com>:
>> Hi guys.
>> I wanted to use Kyngchaos' QGIS 2.14 on my Mavericks Machine (I know its
>> 2016, and were supposed to use Yosemite or El Cap, but there is a long
>> reason for that lol), and I can use it, although the orfeo-toolbox
>> processing does not work.
>> Although the otb apps are available in the package, and it is enabled in
>> Processing, it does not appear in the toolbox.
>> William K, or anyone else, any hints or guidance?
>> Regards, Pieter
>> Qgis-user mailing list
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Ricardo Pinho
> Qgis-user mailing listQgis-user at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160313/3d67d462/attachment.html>
