[Qgis-user] 'Save As' turn Integer to String
Anita Graser anitagraser at gmx.at
Tue Mar 15 13:28:57 PDT 2016
On Tue, Mar 15, 2016 at 6:28 PM, Lene Fischer <lfi at ign.ku.dk> wrote:
> Hi Anita,
> Thanks for the ticket. – I must have overlooked it – tried on the buglist
> first…
> If it´s solved in the master – then the ticket should be closed?
​Not solved yet.
Note: only happens with Integer64 but not with Integer types (as displayed
in the layer properties | fields)
Best wishes,
Anita​
> Regards
> Lene
> *Fra:* anita.graser.at at gmail.com [mailto:anita.graser.at at gmail.com] *På
> vegne af *Anita Graser
> *Sendt:* 15. marts 2016 17:06
> *Til:* Lene Fischer
> *Cc:* qgis-user at lists.osgeo.org
> *Emne:* Re: [Qgis-user] 'Save As' turn Integer to String
> On Tue, Mar 15, 2016 at 3:08 PM, Lene Fischer <lfi at ign.ku.dk> wrote:
> Hi
> Just now trying to save a temp vector file to SHP – all attribute data in
> format Integer is converted into string :-O
> Can this be confirmed ?
> ​Yes, here's the ticket http://hub.qgis.org/issues/14411
> Best wishes,
> Anita​
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160315/36c65774/attachment.html>
