[Qgis-user] 'Save As' turn Integer to String
Alexandre Neto senhor.neto at gmail.com
Wed Mar 16 04:53:17 PDT 2016
Lene, Anita,
Sorry for the noise. Before I have tried with whole integer. Trying with 64
integer I confirm it as well.
Alexandre Neto
Anita Graser <anitagraser at gmx.at> escreveu no dia terça, 15/03/2016 às
20:29:
> On Tue, Mar 15, 2016 at 6:28 PM, Lene Fischer <lfi at ign.ku.dk> wrote:
>> Hi Anita,
>> Thanks for the ticket. – I must have overlooked it – tried on the buglist
>> first…
>> If it´s solved in the master – then the ticket should be closed?
> ​Not solved yet.
> Note: only happens with Integer64 but not with Integer types (as displayed
> in the layer properties | fields)
> Best wishes,
> Anita​
>> Regards
>> Lene
>> *Fra:* anita.graser.at at gmail.com [mailto:anita.graser.at at gmail.com] *På
>> vegne af *Anita Graser
>> *Sendt:* 15. marts 2016 17:06
>> *Til:* Lene Fischer
>> *Cc:* qgis-user at lists.osgeo.org
>> *Emne:* Re: [Qgis-user] 'Save As' turn Integer to String
>> On Tue, Mar 15, 2016 at 3:08 PM, Lene Fischer <lfi at ign.ku.dk> wrote:
>> Hi
>> Just now trying to save a temp vector file to SHP – all attribute data in
>> format Integer is converted into string :-O
>> Can this be confirmed ?
>> ​Yes, here's the ticket http://hub.qgis.org/issues/14411
>> Best wishes,
>> Anita​
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
Alexandre Neto
@AlexNetoGeo
http://sigsemgrilhetas.wordpress.com
http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160316/31ad5f39/attachment.html>
