[Qgis-user] Plugin processing problem
McDonaldR McDonaldR at angus.gov.uk
Thu Mar 17 04:22:32 PDT 2016
Hello List
Every time I open QGIS Essen I get an error message telling me that the Plugin processing will be disabled because it crashed QGIS during the last startup. Please report an issue and re-enable the plugin when the problem has been resolved.
The processing plugin is not enabled.  I have version 2.12.2 installed.  Once QGIS is ready I can enable the processing plugin and open the processing toolbox (the search is slow as has been pointed out in other mails and issues).
Has anyone else experienced this and can you recommend a fix?
I am running QGIS 2.14 on Windows 7 Pro 32bit.
2016-03-17T10:13:23 0 QGIS starting...
2016-03-17T10:14:19 0 Python support ENABLED :-)
2016-03-17T10:17:35 0 Application state:
QGIS_PREFIX_PATH env var: C:/OSGeo4W/apps/qgis
Prefix: C:/OSGeo4W/apps/qgis
Plugin Path: C:/OSGeo4W/apps/qgis/plugins
Package Data Path: C:/OSGeo4W/apps/qgis/.
Active Theme Name: default
Active Theme Path: C:/Users/hdumpty/.qgis2///themes\default\icons/
Default Theme Path: :/images/themes/default/
SVG Search Paths: \\dcnasfs\gis\QGIS\Styles\svg
C:/OSGeo4W/apps/qgis/./svg/
C:/Users/hdumpty/.qgis2//svg/
User DB Path: C:/OSGeo4W/apps/qgis/./resources/qgis.db
Auth DB Path: C:/Users/hdumpty/.qgis2//qgis-auth.db
2016-03-17T10:17:35 0 QGIS Ready!
Thanks
Ross
Ross McDonald | GIS Data Coordinator | Resources Department, IT Division | Angus Council, Angus House, Orchardbank Business Park, Forfar, DD8 1AT
T: 01307 476419 | F: 01307 476401 | E: mcdonaldr at angus.gov.uk<mailto:mcdonaldr at angus.gov.uk>
This message is strictly confidential. If you have received this in error, please inform the sender and remove it from your system. If received in error you may not copy, print, forward or use it or any attachment in any way. This message is not capable of creating a legal contract or a binding representation and does not represent the views of Angus Council. Emails may be monitored for security and network management reasons. Messages containing inappropriate content may be intercepted. Angus Council does not accept any liability for any harm that may be caused to the recipient system or data on it by this message or any attachment.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160317/da2e3c38/attachment.html>
