[Qgis-user] Plugin processing problem
Nathan Woodrow madmanwoo at gmail.com
Thu Mar 17 06:18:28 PDT 2016
If you have one in .qgis2 you should remove that so you don't get conflicts.
On Thu, Mar 17, 2016 at 10:41 PM, McDonaldR <McDonaldR at angus.gov.uk> wrote:
> Thanks Luigi
> C:\OSGeo4W\apps\qgis\python\plugins\processing
> Core processing plugin
> > [general]
> > name=Processing
> > description=Spatial data processing framework for QGIS
> > about=Spatial data processing framework for QGIS
> > category=Analysis
> > version=2.12.99
> > qgisMinimumVersion=2.13
> C:\Users\mcdonaldr\.qgis2\python\plugins\processing\metadata.txt
> Plugin from repo
> > [general]
> > name=Processing
> > category=Analysis
> > version=2.12.2
> > qgisMinimumVersion=2.12
> -----Original Message-----
> From: Luigi Pirelli [mailto:luipir at gmail.com]
> Sent: 17 March 2016 12:25
> To: McDonaldR
> Cc: Nathan Woodrow; Lene Fischer; qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] Plugin processing problem
> May I suggest you to remove
> C:\Users\mcdonaldr\.qgis2\python\plugins\processing folder ?
> I suppose you have an old processing version (loaded after default core
> processing in C:\OSGeo4W\apps\qgis\python\plugins\processing)
> that conflict with 2.14 => it is disabled (that in
> C:\Users\mcdonaldr\.qgis2\python\plugins\processing).
> But the core one still remain loaded correctly.
> let us know
> p.s before to remove
> C:\Users\mcdonaldr\.qgis2\python\plugins\processing, what is the content
> of C:\Users\mcdonaldr\.qgis2\python\plugins\processing\metadata.txt
> Luigi Pirelli
> * Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
> * LinkedIn: https://www.linkedin.com/in/luigipirelli
> * Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
> * GitHub: https://github.com/luipir
> * Mastering QGIS:
> https://www.packtpub.com/application-development/mastering-qgis
> > Db_manager
> > fTools
> > GdalTools
> > MetaSearch
> > Processing
> > Processing Metadata.txt file has the following in it:
> > [general]
> > name=Processing
> > category=Analysis
> > version=2.12.99
> > Gazetteersearch
> > pgRoutingLayer
> > processing
> > processing metadata.txt has the following:
> > [general]
> > name=Processing
> > category=Analysis
> > version=2.12.2
> > From: Nathan Woodrow [mailto:madmanwoo at gmail.com]
> > Sent: 17 March 2016 11:53
> > To: Lene Fischer
> > Cc: McDonaldR; qgis-user at lists.osgeo.org
> > What is in {QGIS Install folder}\apps\qgis\python\plugins
> > e.g C:\OSGeo4W\apps\qgis\python\plugins
> > Is there a processing folder in there?
> > What is in .qgis2\python\plugins?
> > On Thu, Mar 17, 2016 at 9:48 PM, Lene Fischer <lfi at ign.ku.dk> wrote:
> > YES!!!!!!!
> > We have the same problem. One of my students are right at this moment
> > sitting in the class. Installing – re-installing- deleting – REGEDIT
> > The same problem – Processing missing.
> > We now wail for the last installation – pray and hope it will work.
> > Regards
> > Lene Fischer
> > Fra: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] På vegne af
> > McDonaldR
> > Sendt: 17. marts 2016 12:23
> > Til: qgis-user at lists.osgeo.org
> > Emne: [Qgis-user] Plugin processing problem
> > Hello List
> > Every time I open QGIS Essen I get an error message telling me that
> > the Plugin processing will be disabled because it crashed QGIS during
> > the last startup. Please report an issue and re-enable the plugin when
> > the problem has been resolved.
> > The processing plugin is not enabled.  I have version 2.12.2 installed.
> > Once QGIS is ready I can enable the processing plugin and open the
> > processing toolbox (the search is slow as has been pointed out in
> > other mails and issues).
> > Has anyone else experienced this and can you recommend a fix?
> > I am running QGIS 2.14 on Windows 7 Pro 32bit.
> > 2016-03-17T10:13:23 0 QGIS starting...
> > 2016-03-17T10:14:19 0 Python support ENABLED :-)
> > 2016-03-17T10:17:35 0 Application state:
> > QGIS_PREFIX_PATH env var: C:/OSGeo4W/apps/qgis
> > Prefix: C:/OSGeo4W/apps/qgis
> > Plugin Path: C:/OSGeo4W/apps/qgis/plugins
> > Package Data Path: C:/OSGeo4W/apps/qgis/.
> > Active Theme Name: default
> > Active Theme Path: C:/Users/hdumpty/.qgis2///themes\default\icons/
> > Default Theme Path: :/images/themes/default/
> > SVG Search Paths: \\dcnasfs\gis\QGIS\Styles\svg
> > C:/OSGeo4W/apps/qgis/./svg/
> > C:/Users/hdumpty/.qgis2//svg/
> > User DB Path: C:/OSGeo4W/apps/qgis/./resources/qgis.db
> > Auth DB Path: C:/Users/hdumpty/.qgis2//qgis-auth.db
> > 2016-03-17T10:17:35 0 QGIS Ready!
> > Thanks
> > Ross
> > Ross McDonald | GIS Data Coordinator | Resources Department, IT
> > Division | Angus Council, Angus House, Orchardbank Business Park,
> > Forfar, DD8 1AT
> > T: 01307 476419 | F: 01307 476401 | E: mcdonaldr at angus.gov.uk
> > This message is strictly confidential. If you have received this in
> > error, please inform the sender and remove it from your system. If
> > received in error you may not copy, print, forward or use it or any
> > attachment in any way. This message is not capable of creating a legal
> > contract or a binding representation and does not represent the views
> > of Angus Council. Emails may be monitored for security and network
> > management reasons. Messages containing inappropriate content may be
> > intercepted. Angus Council does not accept any liability for any harm
> > that may be caused to the recipient system or data on it by this message
> or any attachment.
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> or any attachment.
> This message is strictly confidential. If you have received this in error,
> please inform the sender and remove it from your system. If received in
> error you may not copy, print, forward or use it or any attachment in any
> way. This message is not capable of creating a legal contract or a binding
> representation and does not represent the views of Angus Council. Emails
> may be monitored for security and network management reasons. Messages
> containing inappropriate content may be intercepted. Angus Council does not
> accept any liability for any harm that may be caused to the recipient
> system or data on it by this message or any attachment.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160317/fb5e30e9/attachment.html>
