[Qgis-user] Plugin processing problem
McDonaldR
McDonaldR at angus.gov.uk
Thu Mar 17 06:40:04 PDT 2016
I’ve removed the one from my profile (.qgis2 folder) and just have the core plugin (2.12.99) installed.
Still get the error message
[cid:image001.png at 01D18050.E9E05FF0]
On another machine (Win 7 Pro 64 bit with Essen installed I have Processing 2.12.99 in the OSGeo4W directory and Processing 2.10.3 in the .qgis2 folder. No error message when starting QGIS. The plugin manager tells me there is a new version available but after clicking the upgrade plugin button there is a red error message saying the .zip archive could not be unpacked. The plugin is deleted from .qgis2 folder. QGIS starts just fine without the error message using the core processing plugin.
So, is there something left over in my registry that’s causing the problem? Where do I start looking?
Thanks
Ross
From: Nathan Woodrow [mailto:madmanwoo at gmail.com]
Sent: 17 March 2016 13:18
To: McDonaldR
Cc: Luigi Pirelli; Lene Fischer (lfi at ign.ku.dk); qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Plugin processing problem
If you have one in .qgis2 you should remove that so you don't get conflicts.
On Thu, Mar 17, 2016 at 10:41 PM, McDonaldR <McDonaldR at angus.gov.uk<mailto:McDonaldR at angus.gov.uk>> wrote:
Thanks Luigi
C:\OSGeo4W\apps\qgis\python\plugins\processing
Core processing plugin
> [general]
> name=Processing
> description=Spatial data processing framework for QGIS
> about=Spatial data processing framework for QGIS
> category=Analysis
> version=2.12.99
> qgisMinimumVersion=2.13
C:\Users\mcdonaldr\.qgis2\python\plugins\processing\metadata.txt
Plugin from repo
> [general]
> name=Processing
> category=Analysis
> version=2.12.2
> qgisMinimumVersion=2.12
-----Original Message-----
From: Luigi Pirelli [mailto:luipir at gmail.com<mailto:luipir at gmail.com>]
Sent: 17 March 2016 12:25
To: McDonaldR
Cc: Nathan Woodrow; Lene Fischer; qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>
May I suggest you to remove
C:\Users\mcdonaldr\.qgis2\python\plugins\processing folder ?
I suppose you have an old processing version (loaded after default core processing in C:\OSGeo4W\apps\qgis\python\plugins\processing)
that conflict with 2.14 => it is disabled (that in C:\Users\mcdonaldr\.qgis2\python\plugins\processing).
But the core one still remain loaded correctly.
let us know
p.s before to remove
C:\Users\mcdonaldr\.qgis2\python\plugins\processing, what is the content of C:\Users\mcdonaldr\.qgis2\python\plugins\processing\metadata.txt
Luigi Pirelli
* Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS:
https://www.packtpub.com/application-development/mastering-qgis
On 17 March 2016 at 13:01, McDonaldR <McDonaldR at angus.gov.uk<mailto:McDonaldR at angus.gov.uk>> wrote:
> Db_manager
> fTools
> GdalTools
> MetaSearch
> Processing
> Processing Metadata.txt file has the following in it:
> [general]
> name=Processing
> category=Analysis
> version=2.12.99
> Gazetteersearch
> pgRoutingLayer
> processing
> processing metadata.txt has the following:
> [general]
> name=Processing
> category=Analysis
> version=2.12.2
> From: Nathan Woodrow [mailto:madmanwoo at gmail.com<mailto:madmanwoo at gmail.com>]
> Sent: 17 March 2016 11:53
> To: Lene Fischer
> Cc: McDonaldR; qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>
> What is in {QGIS Install folder}\apps\qgis\python\plugins
> e.g C:\OSGeo4W\apps\qgis\python\plugins
> Is there a processing folder in there?
> What is in .qgis2\python\plugins?
> On Thu, Mar 17, 2016 at 9:48 PM, Lene Fischer <lfi at ign.ku.dk<mailto:lfi at ign.ku.dk>> wrote:
> YES!!!!!!!
> We have the same problem. One of my students are right at this moment
> sitting in the class. Installing – re-installing- deleting – REGEDIT
> The same problem – Processing missing.
> We now wail for the last installation – pray and hope it will work.
> Regards
> Lene Fischer
> Fra: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org<mailto:qgis-user-bounces at lists.osgeo.org>] På vegne af
> McDonaldR
> Sendt: 17. marts 2016 12:23
> Til: qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>
> Emne: [Qgis-user] Plugin processing problem
> Hello List
> Every time I open QGIS Essen I get an error message telling me that
> the Plugin processing will be disabled because it crashed QGIS during
> the last startup. Please report an issue and re-enable the plugin when
> the problem has been resolved.
> The processing plugin is not enabled. I have version 2.12.2 installed.
> Once QGIS is ready I can enable the processing plugin and open the
> processing toolbox (the search is slow as has been pointed out in
> other mails and issues).
> Has anyone else experienced this and can you recommend a fix?
> I am running QGIS 2.14 on Windows 7 Pro 32bit.
> 2016-03-17T10:13:23 0 QGIS starting...
> 2016-03-17T10:14:19 0 Python support ENABLED :-)
> 2016-03-17T10:17:35 0 Application state:
> QGIS_PREFIX_PATH env var: C:/OSGeo4W/apps/qgis
> Prefix: C:/OSGeo4W/apps/qgis
> Plugin Path: C:/OSGeo4W/apps/qgis/plugins
> Package Data Path: C:/OSGeo4W/apps/qgis/.
> Active Theme Name: default
> Active Theme Path: C:/Users/hdumpty/.qgis2///themes\default\icons/
> Default Theme Path: :/images/themes/default/
> SVG Search Paths: \\dcnasfs\gis\QGIS\Styles\svg<file:///\\dcnasfs\gis\QGIS\Styles\svg>
> C:/OSGeo4W/apps/qgis/./svg/
> C:/Users/hdumpty/.qgis2//svg/
> User DB Path: C:/OSGeo4W/apps/qgis/./resources/qgis.db
> Auth DB Path: C:/Users/hdumpty/.qgis2//qgis-auth.db
> 2016-03-17T10:17:35 0 QGIS Ready!
> Thanks
> Ross
> Ross McDonald | GIS Data Coordinator | Resources Department, IT
> Division | Angus Council, Angus House, Orchardbank Business Park,
> Forfar, DD8 1AT
> T: 01307 476419 | F: 01307 476401 | E: mcdonaldr at angus.gov.uk<mailto:mcdonaldr at angus.gov.uk>
> This message is strictly confidential. If you have received this in
> error, please inform the sender and remove it from your system. If
> received in error you may not copy, print, forward or use it or any
> attachment in any way. This message is not capable of creating a legal
> contract or a binding representation and does not represent the views
> of Angus Council. Emails may be monitored for security and network
> management reasons. Messages containing inappropriate content may be
> intercepted. Angus Council does not accept any liability for any harm
> that may be caused to the recipient system or data on it by this message or any attachment.
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
This message is strictly confidential. If you have received this in error, please inform the sender and remove it from your system. If received in error you may not copy, print, forward or use it or any attachment in any way. This message is not capable of creating a legal contract or a binding representation and does not represent the views of Angus Council. Emails may be monitored for security and network management reasons. Messages containing inappropriate content may be intercepted. Angus Council does not accept any liability for any harm that may be caused to the recipient system or data on it by this message or any attachment.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160317/af50d8cc/attachment.html>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160317/af50d8cc/attachment.png>
