[Qgis-user] Plugin processing problem
Matthias Kuhn matthias at opengis.ch
Thu Mar 17 06:50:25 PDT 2016
Hi Ross,
can you run
import QSettings()
QSettings().remove('/Plugins/watchDog/processing')
in the python console and report back if this fixes the issue?
Matthias
On 03/17/2016 12:22 PM, McDonaldR wrote:
> Hello List
> Every time I open QGIS Essen I get an error message telling me that
> the Plugin processing will be disabled because it crashed QGIS during
> the last startup. Please report an issue and re-enable the plugin when
> the problem has been resolved.
> The processing plugin is not enabled.  I have version 2.12.2
> installed.  Once QGIS is ready I can enable the processing plugin and
> open the processing toolbox (the search is slow as has been pointed
> out in other mails and issues).
> Has anyone else experienced this and can you recommend a fix?
> I am running QGIS 2.14 on Windows 7 Pro 32bit.
> 2016-03-17T10:13:23 0 QGIS starting...
> 2016-03-17T10:14:19 0 Python support ENABLED :-)
> 2016-03-17T10:17:35 0 Application state:
> QGIS_PREFIX_PATH env var: C:/OSGeo4W/apps/qgis
> Prefix: C:/OSGeo4W/apps/qgis
> Plugin Path: C:/OSGeo4W/apps/qgis/plugins
> Package Data Path: C:/OSGeo4W/apps/qgis/.
> Active Theme Name: default
> Active Theme Path: C:/Users/hdumpty/.qgis2///themes\default\icons/
> Default Theme Path: :/images/themes/default/
> SVG Search Paths: \\dcnasfs\gis\QGIS\Styles\svg
> C:/OSGeo4W/apps/qgis/./svg/
> C:/Users/hdumpty/.qgis2//svg/
> User DB Path: C:/OSGeo4W/apps/qgis/./resources/qgis.db
> Auth DB Path: C:/Users/hdumpty/.qgis2//qgis-auth.db
> 2016-03-17T10:17:35 0 QGIS Ready!
> Thanks
> Ross
> *Ross McDonald *|**GIS Data Coordinator | Resources Department, IT
> Division | Angus Council, Angus House, Orchardbank Business Park,
> Forfar, DD8 1AT
> T: *01307 476419* | F: 01307 476401 | E: mcdonaldr at angus.gov.uk
> <mailto:mcdonaldr at angus.gov.uk> **
> This message is strictly confidential. If you have received this in
> error, please inform the sender and remove it from your system. If
> received in error you may not copy, print, forward or use it or any
> attachment in any way. This message is not capable of creating a legal
> contract or a binding representation and does not represent the views
> of Angus Council. Emails may be monitored for security and network
> management reasons.Messages containing inappropriate content may be
> intercepted. Angus Council does not accept any liability for any harm
> that may be caused to the recipient system or data on it by this
> message or any attachment.
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
Matthias Kuhn
OPENGIS.ch - https://www.opengis.ch
Spatial • (Q)GIS • PostGIS • Open Source
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160317/e7287a88/attachment.html>
