[Qgis-user] Plugin processing problem
Matthias Kuhn matthias at opengis.ch
Thu Mar 17 06:52:54 PDT 2016
Sorry I meant to write
import QSettings()
QSettings().remove('/PythonPlugins/watchDog/processing')
Matthias
On 03/17/2016 02:50 PM, Matthias Kuhn wrote:
> Hi Ross,
> can you run
> import QSettings()
> QSettings().remove('/Plugins/watchDog/processing')
> in the python console and report back if this fixes the issue?
> Matthias
> On 03/17/2016 12:22 PM, McDonaldR wrote:
>> Hello List
>> Every time I open QGIS Essen I get an error message telling me that
>> the Plugin processing will be disabled because it crashed QGIS during
>> the last startup. Please report an issue and re-enable the plugin
>> when the problem has been resolved.
>> The processing plugin is not enabled.  I have version 2.12.2
>> installed.  Once QGIS is ready I can enable the processing plugin and
>> open the processing toolbox (the search is slow as has been pointed
>> out in other mails and issues).
>> Has anyone else experienced this and can you recommend a fix?
>> I am running QGIS 2.14 on Windows 7 Pro 32bit.
>> 2016-03-17T10:13:23 0 QGIS starting...
>> 2016-03-17T10:14:19 0 Python support ENABLED :-)
>> 2016-03-17T10:17:35 0 Application state:
>> QGIS_PREFIX_PATH env var: C:/OSGeo4W/apps/qgis
>> Prefix: C:/OSGeo4W/apps/qgis
>> Plugin Path: C:/OSGeo4W/apps/qgis/plugins
>> Package Data Path: C:/OSGeo4W/apps/qgis/.
>> Active Theme Name: default
>> Active Theme Path: C:/Users/hdumpty/.qgis2///themes\default\icons/
>> Default Theme Path: :/images/themes/default/
>> SVG Search Paths: \\dcnasfs\gis\QGIS\Styles\svg
>> C:/OSGeo4W/apps/qgis/./svg/
>> C:/Users/hdumpty/.qgis2//svg/
>> User DB Path: C:/OSGeo4W/apps/qgis/./resources/qgis.db
>> Auth DB Path: C:/Users/hdumpty/.qgis2//qgis-auth.db
>> 2016-03-17T10:17:35 0 QGIS Ready!
>> Thanks
>> Ross
>> *Ross McDonald *|**GIS Data Coordinator | Resources Department, IT
>> Division | Angus Council, Angus House, Orchardbank Business Park,
>> Forfar, DD8 1AT
>> T: *01307 476419* | F: 01307 476401 | E:
>> <mailto:mcdonaldr at angus.gov.uk>mcdonaldr at angus.gov.uk **
>> This message is strictly confidential. If you have received this in
>> error, please inform the sender and remove it from your system. If
>> received in error you may not copy, print, forward or use it or any
>> attachment in any way. This message is not capable of creating a
>> legal contract or a binding representation and does not represent the
>> views of Angus Council. Emails may be monitored for security and
>> network management reasons.Messages containing inappropriate content
>> may be intercepted. Angus Council does not accept any liability for
>> any harm that may be caused to the recipient system or data on it by
>> this message or any attachment.
>> Qgis-user mailing list
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Matthias Kuhn
> OPENGIS.ch - https://www.opengis.ch
> Spatial • (Q)GIS • PostGIS • Open Source
Matthias Kuhn
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160317/53090df0/attachment.html>
