[Qgis-user] Problem Loading Georeferenced image
Nyall Dawson nyall.dawson at gmail.com
Thu Mar 17 13:07:55 PDT 2016
On 18 Mar 2016 06:43, "Gerardo Jiménez" <gejst5 at gmail.com> wrote:
> I  have a georeferenced soil Map. I did the georeferencing in Qgis using
EPSG 26714 as the CRS. I have the following issue. When I load the image in
2.14 the project is set to EPSG 4326. When I load it in 2.8X the project is
set to 26714. I have tested this behavior in two different machines using
win 10 64 bits. In both machines I have the same behavior in the same Qgis
versions. CRS Options for both qgis versions are the same:
> Default CRS for new projects: Automatically enable on the fly
reprojection if layers have different CRS
> CRS for new layers: Use layer CRS
> I have tested also changing from use layer CRS to prompt for CRS. When I
do this, On the fly transformation is activated as if by dafault project
must be in 4326.
> The only work around in 2.14 is to select the layer right click and
choose set CRS from layer. This makes the project to be set at 26714.
> I was use to load my image and that the project was automatically set to
the image CRS. Any one have the same problem? Any one can tell me what
potentially I am doing wrong?
Sounds like http://hub.qgis.org/issues/14392 , which is fixed in master and
2.14.1
Nyall
> Thanks in advance
> Gerardo
> Gerardo Jiménez Delgado
> Instituto de Investigaciones Antropológicas
> Universidad Nacional Autónoma de México
> Ciudad Universitaria s/n, Coyoacan 04510
> México City,México
> tel. 56 22 95 16
> fax. 56 22 96 51
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160318/17159307/attachment.html>
