[Qgis-user] Reading SEG-Y files
Szilard Albert szilard.albert at gmail.com
Fri Mar 18 02:17:38 PDT 2016
Hello,
I would be very much interested in segy read and display ability. I am also
able to read in a segy file, and plot a line map,
and using any other available header (labelling for example).
But I am not sure if the trace data itself is being read. During the load,
I am prompted to select between LayerID=0 (named myfile), and LayerID=1
(myfile_header).
It looks like LayerID=0 has the actual trace headers, while LayerID=1 has
the binary headers. We might need to expect another layer ID for the time
series (trace data)?
Once that successful, I would be interested in creating profiles of various
trace headers and displaying arbitrary lines to check intersections.
Please share your achievements on the issue.
Regards,
Szilard
On 18 Mar 2016 5:01 pm, "Lester Anderson" <arctica1963 at gmail.com> wrote:
> Hi Matt,
> You find the SEG-Y import under the Vector load (open file) - these
> files are not treated as rasters. But I still do not understand how to
> generate a proper plot (i.e. trace image - grey scale or wiggle etc).
> Not found any explanation of the use in QGIS.
> Cheers
> Lester
> On 18 March 2016 at 03:28, Matt Boyd <mattslists at gmail.com> wrote:
> > Hi Lester,
> > where's the seg-y importer located? I haven't been able to find it or a
> > reference to it.
> > Matt
> > On Tue, Mar 8, 2016 at 1:52 AM, Lester Anderson <arctica1963 at gmail.com>
> > wrote:
> >> Hello,
> >> I have just downloaded v2.14 and wanted to test the SEG-Y import. This
> >> all works fine for displaying the line as a series of points in a map,
> >> but is it actually possible to plot the seismic trace itself?
> >> Thanks
> >> Lester
> >> _______________________________________________
> >> Qgis-user mailing list
> >> Qgis-user at lists.osgeo.org
> >> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> >> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160318/ecd7ca96/attachment.html>
