[Qgis-user] Atlas: Filter Empty Pages
Andreas Neumann a.neumann at carto.net
Mon Mar 21 08:41:44 PDT 2016
Hi Albin,
You can do this dynamically. The Atlas filter also accepts geometry
relationship functions. Have a look at the QGIS expression editor.
You can try with the intersects / within / overlaps tests and test
$geometry against @atlas_geometry.
Your filter could look like:
within( $geometry,  @atlas_geometry )
Can you please report back if that works?
Greetings,
Andreas
On 21.03.2016 14:47, Albin Blaschka wrote:
> Am 21.03.2016 um 14:20 schrieb Bernd Vogelgesang:
>> sounds maybe to easy, but why don't you just make a spatial query on
>> your coverage grid to select and save those elements which do have
>> points inside (Grid Layer Contains Points Layer e.g.) and then use
>> that new coverage layer to produce your Atlas?
>> Or do you search for a more clever approach?
>> Cheers
>> Bernd
> Hello Bernd, Joris & List!
> Ah, yes - that would be a possibility, which I did not think of -
> Thank you both!
> ...but in general I was on the quest for a "more clever" meaning here
> "dynamic" approach, I have to admit: So, the aim would be in future,
> just opening the project, printing the atlas without further
> intervention and getting an "up-to-date" atlas...
> But in the meanwhile, it should be ok with the "manual" approach.
> Thanks and greetings!
> Albin
>> Am 21.03.2016, 13:53 Uhr, schrieb Albin Blaschka
>> <albin.blaschka at standortsanalyse.net>:
>> Hello List!
>> I am starting to use the Atlas feature for the first time and had the
>> following problem:
>> I have a coverage-layer (a vector grid) and a point layer (collection
>> sites). At the moment, there are grid cells in which no site (point)
>> is located.
>> My problem is: I would like to filter those "empty"
>> atlas-elements/pages out. In other words, if the atlas-page contains
>> no element of the point layer, it should not get printed/produced.
>> I tried myself and failed, I googled and failed...
>> Is this possible and if yes, how?
>> Thanks in advance,
>> Albin
