[Qgis-user] Atlas: Filter Empty Pages
Joris Hintjens jorishin at gmail.com
Mon Mar 21 06:50:49 PDT 2016
Use Spatial Query to  select the non-empty elements.
1) Give the non-empty elements a new property (with table editor) (1 as opposed to 0 for the empty ones)
2) Or save the selected elements as a new layer
if 1) then filter these elements in the filter option in the atlas configuration
hope it works
Joris
> Op 21 mrt. 2016, om 14:47 heeft Albin Blaschka <albin.blaschka at standortsanalyse.net> het volgende geschreven:
> Am 21.03.2016 um 14:20 schrieb Bernd Vogelgesang:
>> sounds maybe to easy, but why don't you just make a spatial query on your coverage grid to select and save those elements which do have points inside (Grid Layer Contains Points Layer e.g.) and then use that new coverage layer to produce your Atlas?
>> Or do you search for a more clever approach?
>> Cheers
>> Bernd
> Hello Bernd, Joris & List!
> Ah, yes - that would be a possibility, which I did not think of - Thank you both!
> ...but in general I was on the quest for a "more clever" meaning here "dynamic" approach, I have to admit: So, the aim would be in future, just opening the project, printing the atlas without further intervention and getting an "up-to-date" atlas...
> But in the meanwhile, it should be ok with the "manual" approach.
> Thanks and greetings!
> Albin
>> Am 21.03.2016, 13:53 Uhr, schrieb Albin Blaschka <albin.blaschka at standortsanalyse.net>:
>> Hello List!
>> I am starting to use the Atlas feature for the first time and had the following problem:
>> I have a coverage-layer (a vector grid) and a point layer (collection sites). At the moment, there are grid cells in which no site (point) is located.
>> My problem is: I would like to filter those "empty" atlas-elements/pages out. In other words, if the atlas-page contains no element of the point layer, it should not get printed/produced.
>> I tried myself and failed, I googled and failed...
>> Is this possible and if yes, how?
>> Thanks in advance,
>> Albin
> | Dr.rer.nat. Albin Blaschka
> | Etrichstrasse 26, A-5020 Salzburg
> | * www.standortsanalyse.net *
> | * www.researchgate.net/profile/Albin_Blaschka *
> | - It's hard to live in the mountains, hard but not hopeless!
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
