[Qgis-user] Atlas: Filter Empty Pages
Albin Blaschka albin.blaschka at standortsanalyse.net
Mon Mar 21 06:47:17 PDT 2016
Am 21.03.2016 um 14:20 schrieb Bernd Vogelgesang:
> sounds maybe to easy, but why don't you just make a spatial query on
> your coverage grid to select and save those elements which do have
> points inside (Grid Layer Contains Points Layer e.g.) and then use
> that new coverage layer to produce your Atlas?
> Or do you search for a more clever approach?
> Cheers
> Bernd
Hello Bernd, Joris & List!
Ah, yes - that would be a possibility, which I did not think of - Thank
you both!
...but in general I was on the quest for a "more clever" meaning here
"dynamic" approach, I have to admit: So, the aim would be in future,
just opening the project, printing the atlas without further
intervention and getting an "up-to-date" atlas...
But in the meanwhile, it should be ok with the "manual" approach.
Thanks and greetings!
Albin
> Am 21.03.2016, 13:53 Uhr, schrieb Albin Blaschka
> <albin.blaschka at standortsanalyse.net>:
> Hello List!
> I am starting to use the Atlas feature for the first time and had the
> following problem:
> I have a coverage-layer (a vector grid) and a point layer (collection
> sites). At the moment, there are grid cells in which no site (point)
> is located.
> My problem is: I would like to filter those "empty"
> atlas-elements/pages out. In other words, if the atlas-page contains
> no element of the point layer, it should not get printed/produced.
> I tried myself and failed, I googled and failed...
> Is this possible and if yes, how?
> Thanks in advance,
> Albin
| Dr.rer.nat. Albin Blaschka
| Etrichstrasse 26, A-5020 Salzburg
| * www.standortsanalyse.net *
| * www.researchgate.net/profile/Albin_Blaschka *
| - It's hard to live in the mountains, hard but not hopeless!
