[Qgis-user] I ended up with a strange thing when I tried to split a feature
Joshua Kennedy shuaDK at clovermail.net
Sat Mar 26 15:31:03 PDT 2016
ok nevermind I figured it out I was not pressing the correct button on the mouse to finish the split, and couldn’t undo it before then.  thanks!
> On Mar 26, 2016, at 5:52 PM, Azzurra Lentini <azzurralentini at gmail.com> wrote:
> Hi,
> I had several times the same problem but when I printed my map it does
> not appeared in the layout and/or in the paper.. So I just ignore
> that!
> But normally after 2-3 times I open and close the project it disappear.
> I have Win7 and I am using qgis 2.12
> A.L.
> 2016-03-25 21:13 GMT-04:00 Joshua Kennedy <shuaDK at clovermail.net>:
>> Hello
>> I’m getting started with QGIS, have worked with ArcGIS several years ago.
>> I’ve run into an issue and I hope maybe I can get some help here.
>> I was trying to split a polygon feature using the “Split Features” tool in
>> the Advanced Digiitizing toolbar. From there I started trying to draw where
>> I wanted the polygon to be split.  But I was having trouble getting the tool
>> to go in the direction I wanted, and then I ended up with this odd network
>> of line segments on top of the feature I was trying to split.  It’s red with
>> green X nodes and then one dotted red line that goes off into the distance.
>> I can’t undo it. I can’t select it. I remains even when I hide all layers.
>> I  closed the document without saving it and it was still there when I
>> reopened the document.
>> Is this normal, or is it some kind of bug?
>> I’m using QGIS "2.8.1-Wien" on a Mac OSX 10.11.3
>> thanks
>> Joshua
>> Qgis-user mailing list
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Dr. Hydrogeologist
> AZZURRA LENTINI
> Expert of evaluation environmental hazards
> GIS application
> Haity Mobile Tel: 0050946057393
> Italy Mobile Tel.: **(39) 338 24 40 676
> SKYPE azzurrahydro
> *Par respect pour l'environnement,*
> *n'imprimez ce mail qu'en cas d'absolue nécessité*
