[Qgis-user] Symbol translation problem in python plugin
Fernando M. Roxo da Motta petro at roxo.org
Sun Mar 27 11:43:08 PDT 2016
On Sun, 27 Mar 2016 11:20:06 -0300, Arthur Nanni
<arthur.nanni at gmail.com> wrote:
> Dear partners,
> We are translating the Midvatten plugin to Brazilian Portuguese. At
> this moment we have overwrote the UI files into the midvatten plugin
> folder to do a review of terms and sentences. In this procedure we
> have verified that some characters used in Brazilian Portuguese are
> wrong represented (attached). Someone knows how to solve this problem?
  Hi all,
  I am Brazilian, then interested part. ;
  Those strange characters you see are typical of LATIN-1 (ISO8859-1)
encoded text viewed in UTF-8 environment.  In order to see those
correctly you must:
- Convert your environment to ISO8859-1.
or
- Convert that the text to UTF-8.
  The conversion to UTF-8 in Linux environment can be none with the
command:
$ iconv -f iso8859-1 -t utf8 txt_pt_BR-iso.ts > txt_pt_BR-utf.ts
  Do not forget to change the encoding in the XML tag at the start of
file.
  HTH
> The next step is to upload the Midvatten plugin to QGIS official
> plugins repository. Directions to do this are welcome.
> Cheers.
  Roxo
---------------- Non luctari, ludare -------------------+ WYSIWYG
Fernando M. Roxo da Motta <petro at roxo.org>              | Editor?
Except where explicitly stated I speak on my own behalf.|  VI !!
      ( Usuário Linux registrado #39505 )               | I see text,
------------ Quis custodiet ipsos custodes?-------------+ I get text!
