[Qgis-user] Query in QGIS
Joris Hintjens jorishin at gmail.com
Tue Mar 29 13:34:16 PDT 2016
IS there a reason why u use your own map background? WHy not ue an open source map (OSM plugin gives you several)
greetings
Joris
> Op 29 mrt. 2016, om 17:10 heeft Carlos Cerdán <sig.upagu at gmail.com> het volgende geschreven:
> Another thing to check:
> - Is your map file (jpg image) georeferenced?. If not, use Raster --> Georeferencer --> Georeferencer to do it. You must select the same SRC that your points are.
> Good luck
> Carlos Cerdán
> 2016-03-29 7:41 GMT-05:00 Nicolas Cadieux <nicolas.cadieux at archeotec.ca <mailto:nicolas.cadieux at archeotec.ca>>:
> Hi,
> List of things to check:
> Are long/lat inverted?
> Is your other map in the same CRS? (Coordinate Reference system?) If not, it can be fixed by making sure you have "CRS on the fly reprojection" activated in the options.  Also make sure that QGIS "ask" for new layers that have no CRS).
> Nicolas
> On Mar 29, 2016 08:19, "Manoj Soni [via OSGeo.org]" <[hidden email] <http://user/SendEmail.jtp?type=node&node=5258688&i=0>> wrote:
> Dear Users
> Greetings !!
> I am new to QGIS ( Version 2.8) . I have a map file (jpg image) of a district
> I also have an excel file having latitude and longitude of 20 Hospitals in that district.
> So far i have converted that excel file in to tab limited file.
> Then i added one layer in QGIS Desktop and that shows all 20 hospitals as points.
> But these 20 points are showing in open area, not in the district map  boundary.
> How do i put image file and then show 20 hospital in that map.
> Any idea will be grateful.
> Thanks and Regards
> Manoj
> Qgis-user mailing list
> <a href="/user/SendEmail.jtp?type=node&node=5258683&i=0">[hidden email]
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user <http://lists.osgeo.org/mailman/listinfo/qgis-user>
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user <http://lists.osgeo.org/mailman/listinfo/qgis-user>
> If you reply to this email, your message will be added to the discussion below:
> http://osgeo-org.1560.x6.nabble.com/Query-in-QGIS-tp5258683.html <http://osgeo-org.1560.x6.nabble.com/Query-in-QGIS-tp5258683.html>
> To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com <mailto:ml-node%2Bs1560n4125267h38 at n6.nabble.com>
> To unsubscribe from Quantum GIS - User, <a href="http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4125267&code=bmljb2xhcy5jYWRpZXV4QGFyY2hlb3RlYy5jYXw0MTI1MjY3fDYzNDQ4MjQxNg=&#61 <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node&%2361;4125267&code&%2361;bmljb2xhcy5jYWRpZXV4QGFyY2hlb3RlYy5jYXw0MTI1MjY3fDYzNDQ4MjQxNg&%2361;&%2361>;">click here.
> <a href="http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id&%2361;instant_html%21nabble%3Aemail.naml&base&%2361;nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs&%2361;notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>" style="font:9px serif">NAML
> View this message in context: Re: Query in QGIS <http://osgeo-org.1560.x6.nabble.com/Query-in-QGIS-tp5258683p5258688.html>
> Sent from the Quantum GIS - User mailing list archive <http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html> at Nabble.com.
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160329/8fbe493f/attachment.html>
