[Qgis-user] Query in QGIS
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Tue Mar 29 14:04:45 PDT 2016
If you use you use the openlayer plugin, make sure "on the fly CRS" is activated as the plugin will change the project CRS without telling you (look at the CRS in the lower right corner).  OSM layer is always a good place to start if you want to make sure the data is in the right spot.
Nicolas
On Mar 29, 2016 16:21, "Joris Hintjens [via OSGeo.org]" <ml-node+s1560n5258737h8 at n6.nabble.com> wrote:
	IS there a reason why u use your own map background? WHy not ue an open source map (OSM plugin gives you several) greetings Joris Op 29 mrt. 2016, om 17:10 heeft Carlos Cerdán < [hidden email] > het volgende geschreven: Another thing to check: - Is your map file (jpg image) georeferenced?. If not, use Raster --> Georeferencer --> Georeferencer to do it. You must select the same SRC that your points are. Good luck Carlos Cerdán 2016-03-29 7:41 GMT-05:00 Nicolas Cadieux < [hidden email] >: Hi, List of things to check:
Are long/lat inverted? Is your other map in the same CRS? (Coordinate Reference system?) If not, it can be fixed by making sure you have "CRS on the fly reprojection" activated in the options.  Also make sure that QGIS "ask" for new layers that have no CRS).  Nicolas
On Mar 29, 2016 08:19, "Manoj Soni [via OSGeo.org ]" < [hidden email] > wrote:
	Dear Users Greetings !! I am new to QGIS ( Version 2.8) . I have a map file (jpg image) of a district I also have an excel file having latitude and longitude of 20 Hospitals in that district. So far i have converted that excel file in to tab limited file. Then i added one layer in QGIS Desktop and that shows all 20 hospitals as points. But these 20 points are showing in open area, not in the district map  boundary. How do i put image file and then show 20 hospital in that map. Any idea will be grateful. Thanks and Regards Manoj
Qgis-user mailing list
<a href="/user/SendEmail.jtp?type&#61;node&amp;node&#61;5258683&amp;i&#61;0">[hidden email]
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
		If you reply to this email, your message will be added to the discussion below:
		http://osgeo-org.1560.x6.nabble.com/Query-in-QGIS-tp5258683.html
		To start a new topic under Quantum GIS - User, email [hidden email]
		To unsubscribe from Quantum GIS - User, <a href=" http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro&#61;unsubscribe_by_code&amp;node&#61;4125267&amp;code&#61;bmljb2xhcy5jYWRpZXV4QGFyY2hlb3RlYy5jYXw0MTI1MjY3fDYzNDQ4MjQxNg&#61;&#61 ;">click here.
		<a href=" http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro&#61;macro_viewer&amp;id&#61;instant_html%21nabble%3Aemail.naml&amp;base&#61;nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&amp;breadcrumbs&#61;notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml " style="font:9px serif">NAML
View this message in context: Re: Query in QGIS
Sent from the Quantum GIS - User mailing list archive  at Nabble.com . _______________________________________________
[hidden email]
_______________________________________________ Qgis-user mailing list [hidden email] List info: http://lists.osgeo.org/mailman/listinfo/qgis-user Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user _______________________________________________
[hidden email]
		http://osgeo-org.1560.x6.nabble.com/Query-in-QGIS-tp5258683p5258737.html
		To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38@n6.nabble.com
		To unsubscribe from Quantum GIS - User, click here .
		NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Query-in-QGIS-tp5258683p5258744.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160329/35074951/attachment.html>
