[Qgis-user] Selecting records
Pierre-Marie Le Dantec pierremarie.ledantec at gmail.com
Tue Mar 29 21:58:40 PDT 2016
Hi Phil,
For manipulating dates throught SQL you should use ISO format
("YYYY-MM-DD").
Then, you can use a virtual layer with :
SELECT stationid, MAX(obs_date) FROM your_layer GROUP BY stationid
Cheers,
Pierma
2016-03-30 13:09 GMT+11:00 Phil (The Geek) Wyatt <phil at wyatt-family.com>:
> I must be thick, but I can't get my head around this in QGIS
> Data
> stationid_
> obs_date
> BK21
> 28/03/2016
> BK21
> 29/03/2016
> BK21
> 30/03/2016
> BL22
> 28/03/2016
> BL22
> 29/03/2016
> BL22
> 30/03/2016
> BL22
> 31/03/2016
> How do I select the Maximum date for each station ID?
> The data will be coming from a GEOJSON feed but I can also pull it as a
> shape file if needs be
> Cheers - Phil
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
73.64.34
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160330/97b75e12/attachment.html>
