[Qgis-user] Selecting records
Phil Wyatt phil at wyatt-family.com
Tue Mar 29 22:23:49 PDT 2016
Thanks Pierma,
I can sort the dates no worries, so that should work. Many thanks.
Cheers - Phil,
On the road with his iPad
> On 30 Mar 2016, at 3:58 PM, Pierre-Marie Le Dantec <pierremarie.ledantec at gmail.com> wrote:
> Hi Phil,
> For manipulating dates throught SQL you should use ISO format ("YYYY-MM-DD").
> Then, you can use a virtual layer with :
> SELECT stationid, MAX(obs_date) FROM your_layer GROUP BY stationid
> Cheers,
> Pierma
> 2016-03-30 13:09 GMT+11:00 Phil (The Geek) Wyatt <phil at wyatt-family.com>:
>> I must be thick, but I can't get my head around this in QGIS
>> Data
>> stationid_
>> obs_date
>> BK21
>> 28/03/2016
>> BK21
>> 29/03/2016
>> BK21
>> 30/03/2016
>> BL22
>> 28/03/2016
>> BL22
>> 29/03/2016
>> BL22
>> 30/03/2016
>> BL22
>> 31/03/2016
>> How do I select the Maximum date for each station ID?
>> The data will be coming from a GEOJSON feed but I can also pull it as a shape file if needs be
>> Cheers - Phil
>> Qgis-user mailing list
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> 73.64.34
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160330/191c2599/attachment.html>
