[Qgis-user] grid visualisation issue
Carmine Massarelli carmine.massarelli at ba.irsa.cnr.it
Wed Mar 30 05:38:45 PDT 2016
Thanks Andreas,
I found a "small" solutions to visualise the grid: selecting the EPSG
with native DMS (i.e EPSG 4326) it is (re-)projected on the map with
metric coordinates. This is good for my purpose.
Thank you very much Andreas.
Carmine
Il 03/30/2016 01:59 PM, Neumann, Andreas ha scritto:
> Hi Carmine,
> EPSG 32633 is meters based, so you can't label it with DMS.
> If you want to have a grid labeled with DMS, please select a CRS that
> is degree based (e.g. EPSG 4326). Note you can even have several grids
> on the same map: one meter based and one degree based. You could label
> top/left with one system and bottom/right with the other system.
> The grid and grid labels will always be based on the units of the CRS
> set in the grid settings.
> Hope this helps,
> Andreas
> On 2016-03-30 11:05, Carmine Massarelli wrote:
>> Dear,
>> this is what happens when I create a grid in the EPSG 32633:
>> 1. I create a new project with that EPSG;
>> 2. I open a layer in the same EPSG;
>> 3. I open print composer;
>> 4. I create a grid selecting the correct EPSG;
>> 5. I select write coordinates as decimal (native system) and it works
>> perfectly;
>> 6. then I select DMS coordinates format and It seems to refer to
>> random number (in this order for the longitude: -40°, -120°, 160°,
>> 80°, 0°, -80°, -160°, 120°, 40°) but not to the correct DMS for the area.
>> If you want you could download a screenshot from here
>> https://cloud.ba.cnr.it/index.php/s/g2Rd1f8HQprfmoV
>> According to you is it my fault?
>> Thanks
>> Carmine
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160330/ab8a45ed/attachment.html>
