[Qgis-user] grid visualisation issue
Neumann, Andreas a.neumann at carto.net
Wed Mar 30 04:59:52 PDT 2016
Hi Carmine,
EPSG 32633 is meters based, so you can't label it with DMS.
If you want to have a grid labeled with DMS, please select a CRS that is
degree based (e.g. EPSG 4326). Note you can even have several grids on
the same map: one meter based and one degree based. You could label
top/left with one system and bottom/right with the other system.
The grid and grid labels will always be based on the units of the CRS
set in the grid settings.
Hope this helps,
Andreas
On 2016-03-30 11:05, Carmine Massarelli wrote:
> Dear,
> this is what happens when I create a grid in the EPSG 32633:
> 1. I create a new project with that EPSG;
> 2. I open a layer in the same EPSG;
> 3. I open print composer;
> 4. I create a grid selecting the correct EPSG;
> 5. I select write coordinates as decimal (native system) and it works perfectly;
> 6. then I select DMS coordinates format and It seems to refer to random number (in this order for the longitude: -40°, -120°, 160°, 80°, 0°, -80°, -160°, 120°, 40°) but not to the correct DMS for the area.
> If you want you could download a screenshot from here https://cloud.ba.cnr.it/index.php/s/g2Rd1f8HQprfmoV
> According to you is it my fault?
> Thanks
> Carmine
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160330/43b6f82a/attachment.html>
