[Qgis-user] QGIS 2.14.2 crashing on some vector operations
Bo Victor Thomsen
bo.victor.thomsen at gmail.com
Thu May 5 01:47:29 PDT 2016
QGIS 2.14.2 64 bit on Windows 7 has the same problems: Sometimes - but
not always - It will crash and generate a minidump doing a (qgis vector)
clip from Processing. I have not investigated if it's having the same
problem running the clip function from the Vector menu.
Regards
Bo Victor Thomsen
Den 04/05/16 kl. 23:58 skrev Stephane Goldstein:
> Hello.
> I installed QGIS 2.14.2 on Ubuntu 16.04 from the
> http://qgis.org/debian repo.
> When I perform some vector operations, QGIS crashes, and in the
> terminal the only message I get is "Segmentation fault (core dumped)"
> It is crashing when I use the clip and intersect tool for example.
> However I can use other tools likes buffer or polygonize tools without
> any problem.
> In the meantime I've been using versions 2.8.9 and 2.15 from the other
> QGIS repos also without issues. Any ideas on how to fix this ?
> Thanks.
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160505/8a6a9c5c/attachment.html>
