[Qgis-user] How to create valid new shapefiles with qgis and a buffer around?
Marcel Krautkrämer marcelkrautkraemer at mail.de
Thu May 5 02:06:41 PDT 2016
Am Sonntag, 1. Mai 2016, 15:31:30 schrieb Christine:
> Had a look at your *.prj files and they indicate your shapefiles have
> geographic coordinates. If you want to make metric calculations - and a
> buffer is something like that - you should better define your shapefile with
> a projected coordinate system (e. g. Gauss-Krüger or UTM) and choose a
> projection for your project.
> You can easily project you shapes with "save as ..." selecting a projection
> of your choice.
> regards, Christine
> http://osgeo-org.1560.x6.nabble.com/How-to-create-valid-new-shapefiles-with
> -qgis-and-a-buffer-around-tp5263763p5263799.html Sent from the Quantum GIS -
> User mailing list archive at Nabble.com.
Thanks for your support! I changed the projection of my project from epsg
"4326" to "25832" and created a new shapefile with epsg "25832" (my shapefile
had epsg "4326" as projection) an it works! ;-)
