[Qgis-user] Controll QGIS installation
Richard McDonnell richard.mcdonnell at opw.ie
Fri May 6 07:30:51 PDT 2016
Hi Marian,
This suggestion might be not be quite what you are looking for, but have
you looked at
http://live.osgeo.org/en/index.html
Its a Linux Disto with pretty much everything needed, based off Lubuntu,
it should be easy to keep everything up to date also!
Just a suggestion!
Regards,
Richard.
On 06/05/2016 15:18, Tudorache, Marian wrote:
> Hi,
> I have QGIS 2.10 on Centos 7.
> In order to install it I have used:
> yum -y install qgis qgis-grass qgis-python
> It looks like qgis was installed all over the places.
> Is it possible to control the installation to have all necessary files
> in one place?
> Thank kyou,
> Marian
> This electronic message, as well as any transmitted files included in
> the electronic message, may contain privileged or confidential
> information and is intended solely for the use of the individual(s) or
> entity to which it is addressed. If you have received this electronic
> message in error please notify the sender immediately and delete the
> electronic message. Any unauthorized copying, disclosure or
> distribution of the electronic message is strictly forbidden. NAV
> CANADA accepts no liability for any damage caused by any virus and/or
> other malicious code transmitted by this electronic communication.
> Le présent message électronique et tout fichier qui peut y être joint
> peuvent contenir des renseignements privilégiés ou confidentiels
> destinés à l’usage exclusif des personnes ou des organismes à qui ils
> s’adressent. Si vous avez reçu ce message électronique par erreur,
> veuillez en informer l’expéditeur immédiatement et supprimez le. Toute
> reproduction, divulgation ou distribution du présent message
> électronique est strictement interdite. NAV CANADA n’assume aucune
> responsabilité en cas de dommage causé par tout virus ou autre
> programme malveillant transmis par ce message électronique.
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
*_Richard McDonnell_*
*GIS Specialist PgD GIS AssocSCSI*
*OPW FRM Data Management*
*52 Stephens Green, Dublin 2.*
TEL: 01 6476543
OPW - Ag féachaint don am atá le teacht - Ag caomhnú ón am atá thart
OPW - Looking to the future - Caring for the past
Email Disclaimer: http://www.opw.ie/en/disclaimer/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160506/597cf0ba/attachment.html>
