[Qgis-user] Controll QGIS installation
Tudorache, Marian Marian.Tudorache at navcanada.ca
Fri May 6 08:18:09 PDT 2016
Hi Richard,
Thank you for you answer.
QGIS works fine on Centos 7. I am not looking to change the OS.
I am investigating if the rpms can be installed in a directory that I can choose.
I have run Linux command:
rpm -qpi filename.rpm | grep Relocations for each qgis rpm and all are not relocatable. So it seems this is not possible.
It would be nice if you can package all 59 rpms to installed in a location at user choice.
Thank you,
Marian
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Richard McDonnell
Sent: May-06-16 10:31 AM
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Controll QGIS installation
Hi Marian,
This suggestion might be not be quite what you are looking for, but have you looked at
http://live.osgeo.org/en/index.html
Its a Linux Disto with pretty much everything needed, based off Lubuntu, it should be easy to keep everything up to date also!
Just a suggestion!
Regards,
Richard.
On 06/05/2016 15:18, Tudorache, Marian wrote:
I have QGIS 2.10 on Centos 7.
In order to install it I have used:
yum -y install qgis qgis-grass qgis-python
It looks like qgis was installed all over the places.
Is it possible to control the installation to have all necessary files in one place?
Thank kyou,
Marian
This electronic message, as well as any transmitted files included in the electronic message, may contain privileged or confidential information and is intended solely for the use of the individual(s) or entity to which it is addressed. If you have received this electronic message in error please notify the sender immediately and delete the electronic message. Any unauthorized copying, disclosure or distribution of the electronic message is strictly forbidden. NAV CANADA accepts no liability for any damage caused by any virus and/or other malicious code transmitted by this electronic communication.
Le présent message électronique et tout fichier qui peut y être joint peuvent contenir des renseignements privilégiés ou confidentiels destinés à l’usage exclusif des personnes ou des organismes à qui ils s’adressent. Si vous avez reçu ce message électronique par erreur, veuillez en informer l’expéditeur immédiatement et supprimez le. Toute reproduction, divulgation ou distribution du présent message électronique est strictement interdite. NAV CANADA n’assume aucune responsabilité en cas de dommage causé par tout virus ou autre programme malveillant transmis par ce message électronique.
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
Richard McDonnell
GIS Specialist PgD GIS AssocSCSI
OPW FRM Data Management
52 Stephens Green, Dublin 2.
TEL: 01 6476543
OPW - Ag féachaint don am atá le teacht - Ag caomhnú ón am atá thart
OPW - Looking to the future - Caring for the past
[http://www.opw.ie/en/media/opw-email-banner.png]<http://www.opw.ie/>
Email Disclaimer: http://www.opw.ie/en/disclaimer/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160506/2eab9166/attachment.html>
