[Qgis-user] Printed map scale question
Joris Hintjens
jorishin at gmail.com
Mon May 9 02:10:25 PDT 2016
In the print composer, you should see the panel “layout”, if not: g too View>panels>layout. There you can change the paper size. (eg A0 instead of A4).
gives you a larger working area.
This
hope this is what you needed.
Joris
> Op 6 mei 2016, om 13:49 heeft Sarah Gregg <lynkosmail at gmail.com> het volgende geschreven:
> Here I am back again with what may well be a very simple question (though perhaps with a negative answer).
> I have digitalised a zoning map on a 1:25,000 base (for Italian readers, IGM 1:25,000). So far so good. Now I have to render the results in a clearly legible high resolution image for printing.
> To display the full map on the screen, I have to set the scale at 1:185.000 and obviously if I create an image file at this scale using the Composer, even if I set the resolution high, the base map is scarsely legible.
> Is there any way I can get an image of the whole map at, say, 1:75000... apart from creating a whole series of image files and then joining them together using image processing software?
> Many thanks for your advice, Sarah.
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160509/7da037f6/attachment.html>
